The key point is to pick up everything beginning with <tr
etc..... and ending with </tr>, and take care to insert all
of it between a </tr> and <tr etc.....
This works well for smaller tables.
A strategy for sorting bigger tables is:
1. Make the table as simple as possible in RH (borders,
padding, formatting, etc.);
2. Generate print output for the one topic, or just the table
in its own topic;
3. Sort and otherwise manipulate rows and columns in Word;
4. Import the revised table into RH;
5. Strip out all the source code junk from the import (it can
thwart your attempts to reformat the table);
6. Adjust table specs and formatting in RH.
Alternatively, create the table in Word and go to step 4
above.
Yes, step 5 is a pain. But I have gotten pretty proficient
using FAR (or other text editor) to delete everything between
<td etc. and the closing bracket to make it just <td> for
every cell in the entire table. Then I have a bare-bones structure
that responds to RH settings.
Admittedly, a lot of people will not find this method
attractive.
By the way, chazeray, I hope your login name reflects the
stuff you have to read, and not the Help files you publish. (Ho,
ho, in-joke.)
Harvey
