18 Replies Latest reply on Apr 12, 2011 5:57 AM by Jandr123
    FlexPMD View not displaying results Eclipse 3.6
    TucsonJava Level 1
      Below are the relevant software installations. FlexPMD is configured as defined in the documentation.
      When running FlexPMD, it appears to be churning away, however, there are no results that appear in the FlexPMD View window. Is this an issue only with Eclipse 3.6???
      ** Software versions ***
      FlexPMD 1.0.0.v200912091712
      flex-pmd-all-in-one-bundle-1.2
      Eclipse 3.6
      FlashBuilder 4.0.1
      *** Eclipse Log File Entries ***
      !ENTRY org.eclipse.ui 2 0 2011-02-27 10:49:20.167
      !MESSAGE Warnings while parsing the key bindings from the 'org.eclipse.ui.commands' extension point
      !SUBENTRY 1 org.eclipse.ui 2 0 2011-02-27 10:49:20.167
      !MESSAGE Cannot bind to an undefined command: plug-in='com.adobe.ac.pmd.eclipse', id='com.adobe.ac.pmd.eclipse.flexpmd.runCommand.category'
      !ENTRY org.eclipse.ui 4 4 2011-02-27 10:49:20.707
      !MESSAGE Unable to create menu item "com.adobe.ac.pmd.eclipse.toolbar.runCommand", command "com.adobe.ac.pmd.eclipse.flexpmd.runCommand.category" not defined
        • 1. Re: FlexPMD View not displaying results Eclipse 3.6
          Xavi Beumala Level 1
          Can you try uninstalling the version you have and try installing from this temp update site? http://www.rialvalue.com/flexPmd/updateSite/ This is a version to be released
          • 2. Re: FlexPMD View not displaying results Eclipse 3.6
            TucsonJava Level 1
            Thanks, I removed the old version and installed the new one using the url
            provided. Initially, the same results. When I looked at the log, I could see
            there was a permissions error when FlexPMD tries to access one of its temp
            directories (see below)
            !ENTRY com.adobe.ac.pmd.eclipse 1 0 2011-02-28 08:42:17.003
            !MESSAGE [java, -Xmx256m, -jar,
            C:/eclipse/configuration/org.eclipse.osgi/bundles/874/1/.cp/flexPmdRuntime//flex-pmd-comma nd-line-1.1.jar,
            -s,
            C:\workspace\BlissClient\src\com\othenos\bliss\business\DocumentDelegate.as,
            -o, C:\Users\Mike\AppData\Local\Temp\flexpmd5980952838914453410dir]
            !ENTRY com.adobe.ac.pmd.eclipse 1 0 2011-02-28 08:42:22.112
            !MESSAGE Feb 28, 2011 8:42:22 AM
            com.adobe.ac.pmd.engines.AbstractFlexPmdEngine
            WARNING: Access is denied at
            java.io.WinNTFileSystem.createFileExclusively(Native Method)
            java.io.File.checkAndCreate(Unknown Source)
            java.io.File.createTempFile(Unknown Source)
            So, I  quite eclipse and ran it as administrator. This time there FlexPMD
            was able to perform the operations and display the results.
            I do not know if this problem is related to something I have done regarding
            installation of eclipse or if it has something to do with the way FlexPMD is
            installed. Normally, I do not have to run eclipse as administrator to get
            plugins to work. I suspect it has to do with the FlexPMD's creation of the
            temp directory. If there is anything else I can do to help you with this
            issue please let me know.
            Thanks for the fix. I am looking forward to using the capabilities of
            FlexPMD.
            -Mike Robinson
            • 3. Re: FlexPMD View not displaying results Eclipse 3.6
              Xavier Agnetti Adobe Employee
              Any chance you are running on Windows 7?
              It looks like it is actually not related to Eclipse 3.6:
              http://www.javaprogrammingforums.com/file-i-o-other-i-o-streams/5230-file-c
              reatetempfile-throws-exception-win7.html
              Can you try to run this command line:
              Java -Xmx256m -jar
              time/flex-pmd-command-line-1.1.jar -s
              -o .
              If this is the case, we will see what we can do.
              Cheers,
              Xavier
              • 4. Re: FlexPMD View not displaying results Eclipse 3.6
                TucsonJava Level 1
                Yes, running Windows 7.
                Here are the results of the command line:
                Feb 28, 2011 9:30:32 AM com.adobe.ac.pmd.engines.AbstractFlexPmdEngine
                loadRuleset
                INFO: Ruleset:
                C:\Users\Mike\AppData\Local\Temp\default_flex1810577837337907182.xml
                loadRuleset
                INFO: Rules number in the ruleSet: 90
                computeViolations
                INFO: It took 117ms to compute violations
                computeViolationNumber
                INFO: Violations number found: 1
                Feb 28, 2011 9:30:32 AM com.adobe.ac.pmd.engines.FlexPmdXmlEngine
                writeReport
                INFO: Creating report in <C:\Users\Mike\.\pmd.xml>
                writeAnyReport
                INFO: It took 11ms to write the Xml report
                • 5. Re: FlexPMD View not displaying results Eclipse 3.6
                  jerela Level 1
                  I am also having a problem w/ FlexPMD not displaying any results in eclipse.  I am on Windows XP however. I am using FlashBuilder standalone Burrito I6. I tried adding a flag to point to a temp directory, using one that existed on my machine, but that didn't change anything.  PMD had been working on this machine w/ previous FlashBuilder versions.  CPD still works.  I've tried Versions 1.1 and 1.2 with identical results.
                  • 6. Re: FlexPMD View not displaying results Eclipse 3.6
                    cnojima2 Level 1
                    I also have the same issue with it not being able to make the temp. file. I moved my temp folders around, still won't work. I'm using eclipse 3.4.1 w/ Flexbuilder 3. Any ideas?
                    • 7. Re: FlexPMD View not displaying results Eclipse 3.6
                      please can you unsintall your current FlexPMD eclipse plugin and install this yet-not-released version http://www.rialvalue.com/flexPmd/updateSite
                      This new version should fix this problem for you along with several improvements.
                      Xavi
                      • 8. Re: FlexPMD View not displaying results Eclipse 3.6
                        jerela Level 1
                        I think the file you posted is corrupt.  I put it in the dropins folder but eclipse hasn't added flex PMD to preferences.  The file is only 1..2 K in size which seems way too small.
                        • 9. Re: FlexPMD View not displaying results Eclipse 3.6
                          cnojima2 Level 1
                          Thanks for the update. Sadly this still isn't working. I uninstalled and updated using the site you posted. I get this same stack trace
                          java.io.FileNotFoundException: C:\cnojima1\temp\4\flexpmd2731671333939586734dir\pmd.xml (The system cannot find the file specified)
                          at java.io.FileInputStream.open(Native Method)
                          at java.io.FileInputStream.<init>(FileInputStream.java:106)
                          at com.adobe.ac.pmd.eclipse.flexpmd.cmd.FlexPMDResultsParser.parse(FlexPMDResultsParser.java :112)
                          at com.adobe.ac.pmd.eclipse.flexpmd.cmd.FlexPMD.processResultsFile(FlexPMD.java:180)
                          at com.adobe.ac.pmd.eclipse.flexpmd.cmd.FlexPMD.process(FlexPMD.java:68)
                          at com.adobe.ac.pmd.eclipse.flexpmd.cmd.FlexPMD.process(FlexPMD.java:1)
                          at com.adobe.ac.pmd.eclipse.flexpmd.actions.RunFlexPMDJob.run(RunFlexPMDJob.java:83)
                          at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
                          I can run the commandline version (1.2) fine. This is a Windows Server 2003 sp2 x64 box. Let me know if there's any other info I can give you to debug.
                          thanks,
                          -c
                          • 10. Re: FlexPMD View not displaying results Eclipse 3.6
                            @jerela use it as an update site not as a file to in the dropins folder
                            • 11. Re: FlexPMD View not displaying results Eclipse 3.6
                              Hi cnojima2,
                              can you open the errors log view in eclipse and check the messages in there?
                              Also there should be an entry printing the command line executed. Could you try to execute it directly from cmd and see what happens?
                              • 12. Re: FlexPMD View not displaying results Eclipse 3.6
                                cnojima2 Level 1
                                Yup, this works totally fine. I just transformed the [java -Xmx256m -jar ...etc]
                                into the raw
                                and it worked fine.
                                So 3 things happen in the event log:
                                1) the command runs
                                2) i get a warnings:
                                null
                                Info
                                Wed Mar 30 19:09:59 PKT 2011
                                Mar 30, 2011 10:09:59 AM com.adobe.ac.pmd.engines.AbstractFlexPmdEngine <init>WARNING: Access is denied at java.io.WinNTFileSystem.createFileExclusively(Native Method)
                                3) I get an error
                                null
                                Error
                                Error running FlexPMDC:\VENDEV~1\cnojima1\temp\4\flexpmd6740339094822211326dir\pmd.xml (The system cannot find the file specified)
                                java.io.FileNotFoundException: C:\VENDEV~1\cnojima1\temp\4\flexpmd6740339094822211326dir\pmd.xml (The system cannot find the file specified)
                                The directory is created successfully, but it's completely empty (no pmd.xml file exists)
                                • 13. Re: FlexPMD View not displaying results Eclipse 3.6
                                  jerela Level 1
                                  Ok I got it installed but get and error when I run pmd or cpd.
                                  java.lang.NoClassFoundError:  java -Xmx256m -Djava/io/tmpdir=C:/temp
                                  Could not find the main class
                                  since it still new where my custom ruleset was it may have some of the config  left from the old version.
                                  The java arguments are set to  java -Xmx256m -Djava/io/tmpdir=C:/temp
                                  which seems to be what the error is complaining about.
                                  • 14. Re: FlexPMD View not displaying results Eclipse 3.6
                                    @cenojima2 are you on win7? Can you try relaunching Eclipse as admin (right click on Eclipse > Run as administrator) and see if it works
                                    • 15. Re: FlexPMD View not displaying results Eclipse 3.6
                                      @jerela I'm not sure what exact problem are you having. You can reset your configuration from Eclipse > Preferences > FlexPMD
                                      • 16. Re: FlexPMD View not displaying results Eclipse 3.6
                                        jerela Level 1
                                        The problem was what to reset it to.  I was able to install on a different machine and figured out that "java" shouldn't be one of the java arguments .
                                        That fixed it.
                                        • 17. Re: FlexPMD View not displaying results Eclipse 3.6
                                          cnojima2 Level 1
                                          I'm on a Windows Server 2003 x64 sp2 box. I can't run as admin on this box actually so i can't test but the folder is created correctly (so i have rights) but the file isn't there. Running the command line works fine also.
                                          • 18. Re: FlexPMD View not displaying results Eclipse 3.6
                                            Jandr123 Level 1
                                            My eclipse is 3.5.1 and it runs on windows7. I have the same problem. But running flexbuilder as administrator makes the problem go away.
                                            But I don't like having to startup 'as administrator', so please is there another workaround?
