1. Re: Sudden Shutdown of iMacs with 16GB of RAM
Chris Cox
Mar 30, 2011 10:52 AM
(in response to scottgriz)
Not a standard shutdown or kernel panic, but an instant off to black screen.
That means that you have a hardware problem, probably in the RAM, but possibly in the motherboard. (having inadequate power supply to the RAM is a common problem that causes this - could be a bad capacitor, or a bad design)
An Apple technician should be able to put a scope on the power and signal pins of the RAM and see the problem happen (looking for a capacitive discharge pattern in the signals, dropping below signal threshold).
Changing the tile and cache size just changes the RAM access pattern slightly, but doesn't affect GPU usage much.
Yes, Photoshop moves a lot of data in and out of RAM with highly optimized code - which tends to expose problems with the hardware sooner than other applications.
2. Re: Sudden Shutdown of iMacs with 16GB of RAM
Chris Cox
Mar 30, 2011 11:00 AM
(in response to Chris Cox)
I added a note to your Apple discussion with instructions for a technician to find the problem.
Someone competent with a storage oscilloscope and RAM should be able to narrow this down in under an hour.
(which probably means that one of these machines will have to go to a regional repair center, but you don't find oscilloscope experts at the genius bar)
