I am getting a warning in Burrito that it could not load FlexUnitTestRunner_rb.swc and qnx-air.swc and so it won't show me the app in design mode. Did some quick hunting but nothing helpful that I could understand - anybody have any hints. Thanks!
Description Resource Path Location Type
Design mode could not load FlexUnitTestRunner_rb.swc. It may be incompatible with this SDK, or invalid. (DesignAssetLoader.CompleteTimeout)
Design mode could not load qnx-air.swc. It may be incompatible with this SDK, or invalid. (DesignAssetLoader.CompleteTimeout) ChoicesList.mxml
These showed up after running on the BlackBerry Playbook Simulator. The run works well I just can't view the app in design mode anymore.
Dan
I'm getting the same thing, and looking for a solution . . .
Just got this from a friend (Matt) on our Facebook Flash to Mobile group: http://www.facebook.com/home.php?sk=group_169902179710127
Basically Flash Builder can't show the design view because it can't read those two SWCs. One is a UnitTest library, the other is a library for QNX, which is the name of the PlayBook OS. Hopefully, Adobe & RIM will fix that in the final version, but I doubt it will work now while in beta. So just create a new project that is not targeting the PlayBook, copy and paste your files over and then switch over to the design view. A bit of a work-around but I think that should work fine.
MATT
