Hi
My default widget panel only has one widget. Please can someone tell me how do I get more widget to display in theis panel ?
Thanks.
Hi balnco,
Can you please check the following?
1. Is the widget panel wide enough to see all the items? If not, undock it and maximise it to see all the items.
2. What is chosen in the Filter widget dropdown at the bottom of the panel? Is it showing 'All'? If not, can you select 'All' and check?
3. If none of the above works, can you try adding more widgets to the panel by clicking on the 'Browse' button at the bottom of the Widget panel and selecting the widgets you want to add. You can find the widgets in 'Adobe Captivate\Gallery\Widgets' location.
Sagarika
Thanks,3 works, but it only let me add 1 at a time. how do add multiples widget to the panel in one go
Hi balnco,
You can follow one of the following to add multiple widgets to the panel in one go.
1. Copy all the required widgets to the default folder 'Adobe Captivate\Gallery\Widgets' and click on the 'Refresh' button at the bottom of Widget panel. All the widgets in this default folder will be listed in the panel.
(or)
2. Place all the required widgets in a folder and click on 'Change Path' button at the bottom of Widget panel. Select this folder in the Browse dialog. All the widgets in this folder will be listed in the panel.
Sagarika
Thanks,3 works, but it only let me add 1 at a time. how do add multiples at once ?
Date: Wed, 30 Mar 2011 23:00:19 -0600
To: stephen_white22@hotmail.com
Subject: How get more widgets?
Hi balnco,
Sagarika
Hello,
If you want the widgets in all your projects, please do the following when not having any project open:
