Hi
Quite often I notice that I get lots compile errors like "Invalid Embed directive in stylesheet - can't resolve source 'Embed("assets/icons/cancelOnWhite_12x12.png")'. line 165 application.css"
ONLY when there are other compile errors. As soon as I fix these other errors, all "Invalid Embed directive" errors disappear.
Obviously these errors should never show in the first place, and I wonder if this is a known problem with an existing bug report?
I've passed this on to the compiler guys. I've seen this happen before as well.
Cheers,
Anirudh
Hi Anirudh,
did you hear back from the compiler guys?
Cheers
Tom
No. Will keep you posted if I get anything.
I also want to clarify one thing: Design view reports embed errors as well. If you are seeing an error from design view, you should be able to see the "problem" go away and come back when you hit refresh in Design view.
Can you confirm if this is that? If that is so, we've taken care of it in the upcoming release.
I dont use design view, so I guess this does not apply to me.
