1. Re: Panel problem: Lost keyboard focus in Photoshop on Mac OSX
cromaline Mar 31, 2011 5:43 AM (in response to Reimund T)All seems ok on my mac osx system( 10.6.6).
or maybe I misunderstand the problem
2. Re: Panel problem: Lost keyboard focus in Photoshop on Mac OSX
Reimund T Mar 31, 2011 7:08 AM (in response to cromaline)Some keys still seem to work. For instance Shift+Cmd+S will open the Save as dialog, but I can't close it with Esc and I cannot enter a filename.
Cromaline, are you experiencing the same?
3. Re: Panel problem: Lost keyboard focus in Photoshop on Mac OSX
cromaline Mar 31, 2011 8:27 AM (in response to Reimund T)The steps I tried are:
1) click on your panel
2) switch to illustrator
3) switch back to photoshop
4) Open the dialog window by keyboard pressing Shift+Cmn+S
I can type the filename and I can dismiss the save as dialog windows Esc Key without any problem
I tried also other way and other Keys without any problem
If that are the right setps to test the problem, iI can say that all is ok with me
If so try to repair permission on your drive and then to refresh Photoshop preference file
( opening Photoshop pressing at the same time Cmnd+ Opt+Shift )
4. Re: Panel problem: Lost keyboard focus in Photoshop on Mac OSX
Reimund T Mar 31, 2011 8:53 AM (in response to cromaline)Yes, that is the correct steps indeed!
I'm not sure what you mean with "repair permission on your drive" but I tried the Cmd+Opt+Shift suggestion but it did not help
I've also tried exiting all other running applications but that didnt work out either... *pulls hair*
The funny thing is, if you click on the panel once again after losing focus Photoshop regains the focus until you switch application again..
5. Re: Panel problem: Lost keyboard focus in Photoshop on Mac OSX
cromaline Mar 31, 2011 9:16 AM (in response to Reimund T)To repair permission on mac os x:
close all your opened applications open disk utility select on the left column your hard drive and then on the right in the bottom click on " repair disk permission " close when it finish
Not so sure but the problem you have seems to be quite the same kind that happened to someone trying to switch among tools through the keyboard with some panels
6. Re: Panel problem: Lost keyboard focus in Photoshop on Mac OSX
Reimund T Mar 31, 2011 9:54 AM (in response to cromaline)Repair permissions did not help.
Bleh.
7. Re: Panel problem: Lost keyboard focus in Photoshop on Mac OSX
Reimund T Mar 31, 2011 10:36 AM (in response to Reimund T)I've found that if I create an empty panel in Configurator everything works fine. Adding a HTML widget however and clicking it triggers the bug. Ie, the HTML widget is likely the culprit here.
8. Re: Panel problem: Lost keyboard focus in Photoshop on Mac OSX
cromaline Mar 31, 2011 10:51 AM (in response to Reimund T)As I suspected.
there are some thread here about keyboard issue
at the moment I don't remember which one but Im pretty sure there was a solution in some cases
try to take a look.
If I find something that can help you to solve the problem on your computer I will be glad to inform you
Compliment for your panel ,next days I will try it deeper
9. Re: Panel problem: Lost keyboard focus in Photoshop on Mac OSX
Reimund T Mar 31, 2011 11:14 AM (in response to cromaline)On the Configurator forum? I've gone through all five pages can't seem to find any of them. Found one one via Google in another forum though: http://forums.adobe.com/thread/638863?tstart=0
Not much help however.
Thanks a bunch for the help so far btw.
10. Re: Panel problem: Lost keyboard focus in Photoshop on Mac OSX
cromaline Mar 31, 2011 12:34 PM (in response to Reimund T)many and different problems around photoshop keyboard,
also when a panel is not involved, as you can see here
http://forums.adobe.com/message/3437082
Have you updated to the latest osx version?
if not try 10.6.7 that could solve some problem with the keyboard
http://blogs.adobe.com/jnack/2011/03/mac-10-6-7-fixes-photoshop-cs5-conflicts.html
other suggestions could be :
- duplicate the default photoshop keyboard and create a new workspace
or
- try creating a new user account and test there
11. Re: Panel problem: Lost keyboard focus in Photoshop on Mac OSX
Reimund T Mar 31, 2011 1:09 PM (in response to cromaline)Tried all your suggestions. Updated to 10.6.7. New workspace. New user account. Deleted user pref directory. I even reinstalled PS.
Nothing seems to work. >_<
I really, really appreciate your effort though, mr Cromaline! Too bad mr PS is too stubborn. :-/
12. Re: Panel problem: Lost keyboard focus in Photoshop on Mac OSX
cromaline Mar 31, 2011 2:15 PM (in response to Reimund T)so sorry for you
ms cromaline :-)
13. Re: Panel problem: Lost keyboard focus in Photoshop on Mac OSX
Jeffrey Tranberry Mar 31, 2011 7:21 PM (in response to Reimund T)I'll have someone investigate. Sounds like an issue with the HTML widget. The Esc key should return the focus from the panel - always.
14. Re: Panel problem: Lost keyboard focus in Photoshop on Mac OSX
Reimund T Mar 31, 2011 11:39 PM (in response to cromaline)Oh ms Cromaline . I'm so prejudiced.
Jeffrey, sounds good.
15. Re: Panel problem: Lost keyboard focus in Photoshop on Mac OSX
Reimund T May 15, 2011 9:58 AM (in response to Reimund T)Updating to the lastest Photohop and Mac OSX version have fixed this issue for me. Sweet
