Moving from RH 8 for Word to RH 9 HTML
Mar 31, 2011 Mar 31, 2011
Hello,
I have been using RH 8 for Word, outputting to Microsoft HTML Help (*.chm). How do I make the conversion to RH 9 HTML? I open RH 9, and choose Import Microsoft HTML Help, but it's looking for an *.hhp file, of which I have none. I am searching the forums, since this must have a really simple answer, but I can't seem to find it.
Carma
851
I think you can just choose File > Open and browse to your RHWord project. Then there'll be a wizard to choose import options.
Take a backup before you try, just in case something goes wrong.
I haven't done this, so I can't say how clean the conversion is.
Message was edited by: Amebr
Hello Amebr,
Thank you for your response. In the meantime I found a solution. I used RH HTML to import my project as a WinHelp project (hpj) rather than as a Microsoft HTML project (chm). I could never get RH HTML to find and recognize the chm file. I don't understand that issue, but now I have my project imported into HTML so I can proceed.
Carma
Looks like you found the method I was suggesting. That is the best way, as using the CHM you would lose a lot of information about your project. The output (chm) doesn't contain a lot of the administrative information contained in your source (hpj and word files, and possibly other files also).
Apr 01, 2011 Apr 01, 2011
Why don't you just open the projectname.xpj? Doesn't it exist in RH8 for Word?
Hi Jeff
RoboHelp for Word is a different beast than RoboHelp HTML. I believe the project database is a different file type.
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7, 8 or 9 within the day!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
I had no idea Rick - never used it when I got started on TCS2.0.
Yep, it's been around for eons. Actually, it's where RoboHelp's roots are. When I began using it in 1992 it was really not much more than a Word add in. Then later it developed into a fully fledged product. Nowadays though, about the only reason I might suggest using it would be if folks still needed to create WinHelp. Some still do but it's ancient technology for help and hearkens back to Windows 3.1!
Cheers... Rick
SorcerStone Blog
RoboHelp eBooks
Apr 04, 2011 Apr 04, 2011
Hello All,
Here's what I did to solve this problem. I went to RH9 for Word and compiled the project, and output to WinHelp. Then I was able to import the project (hpj) into HTML and proceed from there. When I was using 8, I output to Microsoft HTML (chm) format. RH HTML gives an option to import a Microsoft HTML project, but it is looking for a file of type hhp which I didn't have. My project is now a mess regarding format and fonts, but at least I can work on it.
Background (from another thread): I upgraded to Win 7 and Office 2010. I was also upgrading from RH8 to RH9. I installed RH8 on my new system, thinking that was necessary for the upgrade to 9. Was informed later that I all needed was the serial number from 8. After upgrade to 9, I uninstalled 8. At that point, 9 for Word would open but was not able to communicate with Word 2010, so that I could view the Word docs within RH, but could not edit or save them. (I was able to compile as WinHelp, as mentioned above.) Following suggestions from the other thread, I un/reinstalled 9 but that didn't solve the problem. So now I have 9 installed and I'm using 9 HTML.
I'm going to open a support case with Adobe on the issue of why I can't use 9 for Word. But the problem I posted here is solved.
Carma
RoboHelp Documentation
Download Adobe RoboHelp
