4 Replies Latest reply: Apr 3, 2011 2:09 PM by barpos RSS
    meaning of traceDisplayList() output?
    barpos Community Member
      Here's what that custom class reports (I can't make out where the bold lines come from -- no such thing on the stage or anywhere else in my document):
      [object MainTimeline__Preloader__] root1
           [object Shape] instance1
           [object Loader] instance2
               [object MainTimeline] instance3
                   [object MovieClip] anim_mc
                       [object Shape] instance4
           [object Loader] instance7
               [object MainTimeline] instance8
                   [object MovieClip] backBuilding
                      [object Shape] instance9
                   [object SimpleButton] FullScrnBtn
                   [object SimpleButton] Machining_Btn
                   [object SimpleButton] Welding_Btn
                   [object SimpleButton] SnowBlade_Btn
                   [object SimpleButton] Engineering_Btn
                   [object SimpleButton] Company_Btn
                   [object SimpleButton] Contacts_Btn
                   [object MovieClip] __id0_
                   [object TLFTextField] TraceTxt
                       [object Shape] instance114
                       [object Sprite] instance115
                           [object SimpleButton] instance116
                           [object TextLine] instance118
                   [object MovieClip] instance10
                   [object MovieClip] __id1_
                   [object TLFTextField] CompanyName
                       [object Shape] instance120
                       [object Sprite] instance121
                           [object SimpleButton] instance122
                           [object TextLine] instance124
                               [object Shape] instance125
                   [object MovieClip] instance11
      Where can I find detail explanation how what to expect from a display object list?
      Here's the code for the traceDisplayList() class:
      package
          import flash.display.DisplayObjectContainer;
          import flash.display.DisplayObject;
          public class traceDisplayList
              public function traceDisplayList(kontainer:DisplayObjectContainer,indentString:String=""):void
                  traceF(kontainer,indentString);
              private function traceF(kontainer:DisplayObjectContainer,indentString:String=""):void
                      var child:DisplayObject;
                      for (var i:uint = 0; i < kontainer.numChildren; i++)
                          child = kontainer.getChildAt(i);
                          trace(indentString,child,child.name);
                          if (kontainer.getChildAt(i) is DisplayObjectContainer)
                              traceF(DisplayObjectContainer(child),indentString + "\t");
        • 1. Re: meaning of traceDisplayList() output?
          Ned Murphy CommunityMVP
          If this is a custom class written by someone and provided for public use, then the answer to your questions about what it is for probably lies in whatever writeup that person provides where they make this class available.  Otherwise, what you see is what you get, a hierarchy-indented list of all the objects (each one's data type and instance name) found in whatever container object that was passed into the function.
          • 2. Re: meaning of traceDisplayList() output?
            kglad CommunityMVP
            you're tracing the displayobject, displayobject.name and all its children.
            • 3. Re: meaning of traceDisplayList() output?
              Well, the sample code provided came with the suggestion to pass "stage' as parameter.  With "this" instead, the trace report listing makes more sense.
              [object MovieClip] __id0_            // no such movie clip on my stage
              [object MovieClip] instance10     // no such movie clip on my stage
              [object MovieClip] __id1_          // no such movie clip on my stage
              [object MovieClip] instance11   // no such movie clip on my stage
              It's only my two text fields (CompanyName & TraceTxt) on the stage that make absolutely no sense.  Three lines for a single object.  This has a be a Flash bug (not that the bug is animated <g>).
              If I remove my two text fields from the stage, I get the following display list:
              Ron
              • 4. Re: meaning of traceDisplayList() output?
                If I convert my TLF text fields to Classic text fields, everything is fine!  So, that's what I'll do ...
                Ron
