0 Replies Latest reply on Apr 5, 2011 11:10 AM by cosmits
    flex 3 client sends each request 3 times to CF9
    cosmits
      Hi all
      my problem is very streight forward
      have a flex 3 app with a CF9 backend
      when I run it locally (jrun) all is well, which means each call to the server (Remoting AMF...) is being called once, as you would expect
      when I the same app on the remote testing server, I get 3 calls for each call to the server, these are observed by the sniffer i use (ServiceCapture...)
      I also noticed in the first 2 calls details - HTTP Error 401. The requested resource requires user authentication.
      the third one contains the actual data which is being transfered back & forth...
      so it seems like the client and the server are negotiating till the data is passing... strange
      apart from the redundency, this particularly troubles me when the app sends emails, because for some reason, it sends them twice
      I've ruled out the mail configuration as the cause by testing a simple script on the server that sends a simple email - only once
      but when it is being invoked from the flex app, it is being send twice...
      does anyone encountered anything similar?
      care to share your insights on the matter?
      cheers
