Need help with inserting bullets into form using LiveCycle. I'm a newbie and appreciate any help. Thanks.
Solved! Go to Solution.
Total Likes
Are the items to be bulleted a series of text boxes or is it a list box?
If it is a series of text boxes, you can add a circle object. Adjust it to be a heck of a lot smaller than the default (hold down shift and drag the corners in). Add a fill color (not the default white or you won't see the color). Repeat as necessary.
If it is a list or drop down box then is gets more interesting. You would have to concatenate a bullet to the front of the list items, AFAIK. The gurus here may (probably) have better information.
Total Likes
Could you expand on that? Do you mean bullet points like this:
Total Likes
Yes
Total Likes
Total Likes
That works like a charm; fortunately I don't need a lot of them. Thanks a bunch.
Total Likes
In a text box, try creating your bullet list in Word and then copy and paste. You can adjust space between bullet and text
Total Likes
