Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
Populate form fields using DataConnection and SQL query
Avatar
Level 1
Hi. I have a local database. I can connect to it from my form which has several text fields binded to the DataConnection fields.
The idea is to locate a certain record in the database and fill these fields with corresponding values.
I have a button whith defined click event with the following simplest script
topmostSubform.Page1.Button1::click - (JavaScript, client)
xfa.sourceSet.DataConnection.resolveNode("#command").query.commandType = "text";
xfa.sourceSet.DataConnection.resolveNode("#command").query.select
= "SELECT * FROM records WHERE InternalID = '000-00-0024'";
xfa.sourceSet.DataConnection.open();
No errors or warnings, but the fields are not updated with new values (those are set with the first record of the table).
The event handler works - I tried to execure some code in there.
If any ideas how to fix it please drop me a line.
MaxCompana
Avatar
Level 1
Maybe you have found solution since...? Im also trying to populate through odbc certain fields on the form, which must change when primary/unique field is updated. Please advise me of how such can be assembled. Thanks
Avatar
Level 1
Hi, i just gave up and wrote a C++ program to be an "interface"for the
forms. It is not an elegant solution but it a fast and easiest one. Good
luck. Let me know if you succeded with the forms... i didnt...
