Hello!
What causes could prevent autocompletion from working in Flash Builder burrito? in flash builder 4 it works fine, but not at all in burrito. maybe I changed some settings somehow? If i open Settings->Flash Builder->Editors then "Enable Auto Activation" under "Code Assist" is checked.
what other reason could there be for that problem?
Are you using 'Flash Builder Burrito Preview'? You might have faced this known issue https://bugs.adobe.com/jira/browse/FB-28451 . This is fixed in future builds of Flash Builder.
Workaround is, Click 'Restore defaults' in Preferences->Flash Builder->Editors->ActionScript Code->Content Assist Cycling
Or Changing workspace.
Let us know if this workaround solves the issue.
-Radhakrishna
Can you please be specific on which autocompletion is not working, type, variable, function names, or something else? Along with this a simple code sample would be more helpful for us to troubleshoot.
Shylendra
all of them.
example: i create a new ActionScript only project, click in the mainclass and type
var asdf:
autocompletion doesn't popup.
if I import TextField manually and then type
var asdf:TextField = new TextField();
asdf.
again nothing happens.
Can you please attach the workspace log. It can be found in <workspace location>/.metadata/.log.
Also are you using an old workspace, created by FB4? If yes, try creating a new workspace and see if it happens.
-Shylendra
-Radhakrishna
yap, that did do the trick!
thank you!
