1. Re: Very Poor Resolution in Titles
John T Smith Apr 8, 2011 8:39 AM (in response to mdubuque)You have replies in your Encore posting
http://forums.adobe.com/thread/835694?tstart=0 -
2. Re: Very Poor Resolution in Titles
Harm Millaard Apr 8, 2011 8:44 AM (in response to mdubuque)Matt,
Several problems in your workflow with the current capabilities of PR. You are going from HD to SD. That will of course lead to degradation of your titles in terms of resolution. You probably need those titles during editing in order to place them at the exact location you want and these is no way you can currently designate a track to be exported as a subtitle track to Encore. I have repeatedly filed feature requests to that extend. Maybe you should do the same. With hard baked titles from PR there is no way to turn them on or off in Encore. Life would be so much easier if one could just export a designated track from PR as a subtitle track with the correct timecodes to EN and it would likely solve your subtitle problem about resolution, because there would not be any downrezzing involved.
3. Re: Very Poor Resolution in Titles
mdubuque Apr 8, 2011 12:04 PM (in response to Harm Millaard)Thanks John and Harm. Excellent feedback in Encore post. Still have a few questions over there.
Harm, I do have a substantial portion of this that I could do as subtitles. Is that a superior approach generally to some of my text I want to present for the reader to view?
Should I apply subtitles in Encore? Is that a coherent approach to presenting written material on the screen?
thanks, I'm getting up to speed here.
Matt
4. Re: Very Poor Resolution in Titles
Bill Hunt Apr 8, 2011 1:43 PM (in response to mdubuque)Matt,
True Subtitles are a function in Encore for either a DVD/BD Video, or for an authored Flash DVD.
The closest that one can come in PrPro would be Lower-thirds, which would be burned into the Video on Export.
Good luck,
Hunt
5. Re: Very Poor Resolution in Titles
Bill Hunt Apr 8, 2011 1:44 PM (in response to mdubuque)Matt,
I cannot recall if I posted this ARTICLE in the Encore thread, and if I did, I apologize.
Good luck,
Hunt
6. Re: Very Poor Resolution in Titles
mdubuque Apr 8, 2011 3:20 PM (in response to Bill Hunt)Thanks Bill. I'd like "great" titles as the article describes it. Is it impossible to obtain great titles if I encode it in DV format in Encore?
I don't know of any other options for this one festival that insists on it being in standard definition.
Difficult choice because I have big hopes for some complex titles.
Thanks it's a great article, very very helpful....
Matt
7. Re: Very Poor Resolution in Titles
Bill Hunt Apr 8, 2011 4:05 PM (in response to mdubuque)Well, SD is, well, er-r, not that great, at least by the standards set by BD. Once, we accepted the SD Titles, but now that we've become accustomed to BD and HD output, it does look rather bleak. Still, when one does all that they can, they do not look that bad. This is especially true, if the DVD-Video is played on a good, up-rezzing BD/DVD player hooked to an HD TV set.
If you are doing an HD Project, that is then down-rezzed to SD, things might ever be at their maximum. Such is the plight of down-rezzing.
I think that there might have been a link posted to Jeff Bellune's HD to SD tutorial, and that is about as good as it gets, if one uses a good font, with enough weight and sans-serif, of an adequate size.
It's too bad that Video cannot directly use Vector Art, but that is the "nature of the beast."
Good luck,
Hunt
8. Re: Very Poor Resolution in Titles
mdubuque Apr 8, 2011 5:20 PM (in response to Bill Hunt)Thanks Bill, I marked your answer as correct.
Two final questions.
What does "BD" stand for below?
What does the word "enough weight" mean when you say "good font with enough weight"?
Thanks for all your help. Light at the end of the tunnel!
Matt
9. Re: Very Poor Resolution in Titles
Bill Hunt Apr 8, 2011 6:15 PM (in response to mdubuque)BD = BluRay Disc. You will also see it as BR, and possibly BRD.
For "weight," this is the thickness of the fonts' strokes. This could be just by design, or Bold, Ultra-Bold or Black. Some fonts have weight by their design, and some allow for greater weight with other attributes.
I end up using a lot of Alburtus, Arial, Berthold, Franklin Gothic, Gil Sans, Kozuka, Helvetica and Myriad Titles, and my choice is often based on the fact that I have so many options in most of those families.
In Extensis Suitcase, I have a Group just for Video work, and many of those also appear in several "client Groups."
Good luck,
Hunt
PS - typography in Video is not nearly half as much fun as graphic layout work, but that is just life.
10. Re: Very Poor Resolution in Titles
Powered by Design Apr 9, 2011 8:56 AM (in response to mdubuque)What are the setting for the sequence you are editing ?
You say you have 1920x1080 source. Are you editing in a HD sequence then trying to export to SD ?
Or are you editing in SD and resizing your HD to fit ?
It sounds like you are editing and creating titles in HD then trying to go to SD.
Since you have to go to SD maybe start with a SD timeline and create your title there so they dont have to be resized on export to Encore.
GLenn
11. Re: Very Poor Resolution in Titles
mdubuque Apr 9, 2011 3:33 PM (in response to Powered by Design)Thanks. Yes, I am editing in HD and then down rezzing to SD.
In this complex domain, I'm thinking that, all things considered I should adhere carefully to the guidelines in this link:
http://library.creativecow.net/articles/hodgetts_philip/titles.php
and do the titles dynamically linked (if that is the correct term) in After Effects.
Clearly some complex tradeoffs here.
I'm grateful for the help!
Matt
