1. Re: geometricBounds not defined for placed image
pkahrel Apr 11, 2011 9:04 AM (in response to cweger79)Maybe you could try this approach:
- take the width of reportFrame
- place the inline
- make the inline's parent (i.e. the rectangle) as wide as reportFrame
- fit the rectangle by using one of the fit options.
Peter
2. Re: geometricBounds not defined for placed image
pkahrel Apr 11, 2011 9:23 AM (in response to cweger79)You need in fact to use fit() twice:
if (inline.isValid) {
var gb = inline.geometricBounds;
gb[3] = reportFrame.geometricBounds[3];
inline.parent.geometricBounds = gb;
inline.parent.fit (FitOptions.proportionally);
inline.parent.fit (FitOptions.frameToContent);
}Peter
3. Re: geometricBounds not defined for placed image
cweger79 Apr 11, 2011 9:31 AM (in response to pkahrel)Hi Peter,
Thanks for your suggestions. However, they don't work (for me, anyway) because, even though inline.isValid=true, inline apparently has no geometricBounds. The script fails on this line:
If I look in the Data Browser, next to "geometricBounds" for the "inline" object, it says "Invalid object for this request."
This is the case, even though the graphic HAS been placed, and if I stop the script I can resize and fit it in the parent textFrame using the UI.
This is on CS5 Windows 7.0.3.535. I haven't tried it yet on Mac.
Chuck
4. Re: geometricBounds not defined for placed image
pkahrel Apr 11, 2011 10:22 AM (in response to cweger79)Strange. It works ok for me. Don't know what to suggest now. . .
5. Re: geometricBounds not defined for placed image
cweger79 Apr 11, 2011 10:35 AM (in response to pkahrel)Peter,
It fails for me when the placed graphic is too large to fit within the bounds of the textFrame. If the graphic is small enough to fit, it works fine.
Unfortunately, most of the graphics I am working with are larger than the textFrames in which I am placing them, so the script mostly fails.
Have you tried it with a graphic larger than the frame? And are you using Mac or Windows?
Thanks for exploring this.
Chuck
6. Re: geometricBounds not defined for placed image
Dirk Becker Apr 11, 2011 11:44 AM (in response to cweger79)If you need the geometric bounds of a newly placed inline item, make sure the parent frame is composed - I've occasionally had that fail at least on InDesign Server CS4.
Of course Chuck is also right with the size of the inline vs. parent frame.
Before resizing, I'd also try to clear that text frame option that limits the inlined object into the frame.
Dirk
7. Re: geometricBounds not defined for placed image
cweger79 Apr 11, 2011 12:24 PM (in response to Dirk Becker )Hi Dirk,
Thanks for chiming in. Unfortunately, you also have failed to provide a correct answer, so IBM's Watson remains in the lead.
Here's what I've done to disprove your theory:
A. Manually, in the UI
1. Created a new empty InDesign document
2. On page 1 of that document, drew a text frame about 5x5 inches
3. Chose Object->Text Frame Options, and made sure the "Ignore Text Wrap" checkbox was checked
4. In that same text frame, typed "Hello, world" followed by a carriage return
5. With the text cursor still active, chose File->Place, and placed a large (9.6" wide x 7.5" high) PNG image.
The image does not appear in the frame (naturally), and the overflow mark showed up in the lower right corner of the frame. As expected.
Now, in ExtendScript, I ran the following script:
var myFrame = app.activeDocument.textFrames.item(0); // there's only one frame in the document
myFrame.recompose(); // just in case that makes a difference
var inlineImage= myFrame.allPageItems[0];
var g = inlineImage.geometricBounds;This script fails on the last line with the message "Invalid object for this request." It has the right pageItem, but the pageItem does not report its bounds.
HOWEVER, and here's the interesting part:
IF I manually make the textFrame tall enough so that it's at least as tall as the image, THEN the image appears in the frame (extending beyond the right edge, because I haven't made the frame any wider, only taller).
And THEN the script runs fine.
I'm sure someone somewhere had a good reason for this behavior, but I can't work out the logic behind it. In any event, there seems to be no way to obtain the bounds of an inline pageItem that's taller than the frame. Wider is OK, but taller causes the failure described above.
I don't know if this behavior is historic or new in CS5. For now, I'm just going to use my extremely kludgy workaround (see original post in this thread).
Thanks again, Peter and Dirk. As always, your help is appreciated.
Chuck
8. Re: geometricBounds not defined for placed image
Harbs. Apr 11, 2011 12:34 PM (in response to cweger79)Hi Chuck!
You can try using pageItem.resolve() and pageItem.reframe() or resize(). I'm pretty sure that works even if it's not composed.
This is one of those things that I've been meaning to try for a long time already, but work keeps getting in the way...
Harbs
9. Re: geometricBounds not defined for placed image
Dirk Becker Apr 11, 2011 12:45 PM (in response to cweger79)Chuck,
as you found, isValid is not sufficient for inlines in overset. It just says whether your object specifier points to an existing object.
To check for overset at a particular position, we examine the parentTextContainers of the image's storyOffset (that would be your insertionPoint).
Another approach could temporarily resize the enclosing text frame. Note that with severe overflow if the parent text frame exceeds the pasteboard size, you'd then find your inlines assembled at the bottom there, with wrong bounds.
Finally, you could place the image as regular page item and only move it inline when you're done with scaling ...
Dirk
10. Re: geometricBounds not defined for placed image
Harbs. Apr 11, 2011 12:51 PM (in response to Harbs.)I just quickly tried playing with resolve, reframe and resize, and I quickly remembered why I put this off to a quiet day (which doesn't seem to come).
The API makes my head hurt trying to figure out the correct parameters to plug in...
If you get it working, let me know!
Harbs
11. Re: geometricBounds not defined for placed image
cweger79 Apr 11, 2011 1:36 PM (in response to Harbs.)Thanks to all for your help. Here's the solution at which I finally arrived (I'm sure this can be improved upon, feel free to comment):
var reportFile = new File("foo.png");
// the parent textFrame:
var parentFrame = app.activeDocument.textFrames.item(0); // there's only one frame in this test document
parentFrame.recompose(); // just in case it makes a difference
var parentBounds = parentFrame.geometricBounds;// place the file inline, at the end of the text in the parentFrame:
var insPoint = parentFrame.insertionPoints.lastItem();
var inlineFrame = insPoint.place(reportFile)[0].parent; // need "parent" because otherwise we'd get the placed image; we need its parent rectangle// in case the placed frame is too tall for the parentFrame, we need to reframe it:
if (parentFrame.overflows) {
var opposingCorners = [[parentBounds[0],parentBounds[1]], [parentBounds[2], parentBounds[3]]];// the parent frame's bounds as an array of two [y,x] arrays
inlineFrame.reframe(CoordinateSpaces.INNER_COORDINATES, opposingCorners);
}// now make sure the inlineFrame fits exactly into the parentFrame horizontally, fit the image so it fits into the inlineFrame, and finally shrink the inline Frame to match the image:
var inlineBounds = inlineFrame.geometricBounds;
inlineFrame.geometricBounds = [inlineBounds[0], inlineBounds[1], parentBounds[2], parentBounds[3]]; // same bounds, but set the inline frame in so it matches the parent frame's bottom right
inlineFrame.fit(FitOptions.PROPORTIONALLY);
inlineFrame.fit(FitOptions.FRAME_TO_CONTENT);It was Harbs' suggestion regarding pageItem.reframe() that put me on the right track. The "gotcha" here is that reframe REQUIRES that you work in points; I haven't shown the requisite "set the units to points" code, but it needs to be there for this to work right.
Thanks again to all.
-Chuck
12. Re: geometricBounds not defined for placed image
Laubender Apr 13, 2011 8:53 AM (in response to cweger79)Chuck,
I wonder If your script will work in every case. I had occasional issues and "interesting" results in testing it with InDesign CS4 6.0.6 (German).
It seems to me that a special relationship between text frame size and picture size is necessary. Somehow unpredictable…See screen grabs from two working examples and two not working example (resulting in text overflow; in my German version tagged as "Übersatz" in the story panel, thus the "UE" in the links panel instead of a page number).
Working example 1 BEFORE script execution (notice the ratio of the text frame):
Working example 1 AFTER script execution:
Working example 2 AFTER script execution (this time a more extreme ratio of width x height):
And here an example for a not working situation resulting in text overflow:
First I thought it would be wise to end the text with end paragraph, but the following example shows, that there could be text overflow as well:
It seems to me there must be a minimum height or width of the text frame depending of size and/or ratio of the picture you want to place.
Btw, there's no difference if you use points or millimeter. Tested both.Uwe
13. Re: geometricBounds not defined for placed image
cweger79 Apr 14, 2011 5:58 AM (in response to Laubender)Hi Uwe,
Hmmm, I think you are correct. I'll have to return to my secret laboratory to see if I can come up with a more robust version.
Chuck
