[2011-04-09:10:54:04] Runtime Installer begin with version 2.6.0.19120 on Windows XP x86
[2011-04-09:10:54:04] Commandline is:
[2011-04-09:10:54:04] No installed runtime detected
[2011-04-09:10:54:06] Starting runtime install. Installing runtime version 2.6.0.19120
[2011-04-09:10:54:06] Installing msi at c:\docume~1\myusername\locals~1\temp\air109.tmp\setup.msi with guid {AFF7E080-1974-45BF-9310-10DE1A1F5ED0}
[2011-04-09:10:54:10] Launching subprocess with commandline c:\Program Files\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR Updater -installupdatecheck
[2011-04-09:10:54:10] Runtime Installer end with exit code 0
[2011-04-09:10:54:11] Runtime Installer begin with version 2.6.0.19120 on Windows XP x86
[2011-04-09:10:54:11] Commandline is: -installupdatecheck
[2011-04-09:10:54:11] Installed runtime (2.6.0.19120) located at c:\Program Files\Common Files\Adobe AIR
[2011-04-09:10:54:12] Performing pingback request
[2011-04-09:10:54:12] Pingback request completed with HTTP status 200
[2011-04-09:10:54:12] Starting runtime background update check
[2011-04-09:10:54:12] Begin Background update download from http://airdownload.adobe.com/air/3/background/windows5.1/x86/patch/2.6.0.19120/update
[2011-04-09:10:54:12] Unpackaging http://airdownload.adobe.com/air/3/background/windows5.1/x86/patch/2.6.0.19120/update to C:\Documents and Settings\conlinc\Application Data\Adobe\AIR\Updater\Background
[2011-04-09:10:54:12] Runtime update not available
[2011-04-09:10:54:12] Unpackaging cancelled
[2011-04-09:10:54:12] Runtime Installer end with exit code 0
Currently 2.6.0.19120 is the latest public release version, so it is the expected result that there is no runtime update available.
Jian
Thanks Jian.
The reason I posted this logfile is because whenever I attempt to run the
installer that came with my Motorola Cable Modem on my Windows XP box, a dialog
box tells me that it is "Initializing the Installation", but then the installer
never runs. Initially, it gave me an error message about installing Adobe AIR,
so I manually installed Adobe AIR. Now, it just silently fails, and so I was
hoping that something in the AIR logfile would identify the cause of the silent
failure.
Can you help me troubleshoot this? What else can I do to identify why the
installer is silently failing?
Cindy
Could you try the following commands in command line and paste the outputs and AIR install log here again?
1. <AIR Runtime Installer> -info
2. <AIR Runtime Installer> -uninstall
3. <AIR Runtime Installer> -silent
Thanks for your help. I ran the steps you suggested, but still could not get
the installer that uses AIR to run (it failed silently). Could this be related
to the fact that I'm trying to install this on a work laptop? (I don't have
administrator privileges on the machine, or it may be locked down in some other
way.)
Below is the log of what I tried:
C:\Downloads>AdobeAIRInstaller.exe -info
C:\Downloads>This is an installer for Adobe AIR 2.6.0.19120
Adobe AIR 2.6.0.19120 is installed.
Scheduled install type: patchSame
Note: this never returned to the command prompt, so I killed it with Ctrl+C
C:\Downloads>AdobeAIRInstaller.exe -uninstall
C:\Downloads>Uninstalling Adobe AIR(all versions)
AdobeAIRInstaller.exe -uninstalldone
C:\Downloads>AdobeAIRInstaller.exe -silent
C:\Downloads>Adobe AIR is currently not installed
Installing version 2.6.0.19120
done
It should be the root cause. Can you get the administrator privilege on that machine and try again?
