9 Replies Latest reply: Apr 12, 2011 8:31 AM by Jeremy bowmangraphics RSS
    XML tag markers moved: Find and Replace causing problem in xml elements
    Green4ever Community Member
      Hi All,
      I am doing find and replace using GREP. While using the expression like $1, $2 (Found Items) in the change to field it changes the placement of tag marker. If the found item is a part of two of more xml elements, I am getting a serious problem while replacing it. (ie. The xml tag markers are moved.)
      See the screen shot below, then you may get better idea. And help me to overcome this issue.
      This is just an example to show you what i'm trying to say, there are so many cases like this.
      Original text/ Before doing find replace
      After replacing
      Green4ever
