FormDataIntegrationClient.importData() deletes layout information
Avatar
Level 2
I have a pdf document in which every field that has changed is marked in red. I extract XML from it, change one field and import the data into the same pdf document. After that all fields that were red before are not anymore.
Code example:
inPdfDocument.copyToFile(new File("/home/arne/fooooooooo.pdf"));          // <-- contains red fields
FormDataIntegrationClient dataClient = FormDataIntegrationClientFactory.createClient();
Document inXmlDocument = new Document(inXML);
Document resultPDF = dataClient.importData(inPdfDocument, inXmlDocument);
resultPDF.copyToFile(new File("/home/arne/barrrrrrrrrrrr.pdf"));                    // <-- contains no red fields.
How can I add data to a pdf without losing layout information?
Thanks in advance for your answer.
Cheers,
Arne
1 Reply
Avatar
Level 2
Perhaps there is a possibility to extract the layout information somehow and insert it after this step? How?
