Learn about Edge Delivery Services in upcoming GEM session
Problem with populating dynamic drop down
Avatar
Level 2
I am hoping someone can help.
I have a process that is retrieving a series of codes from a table. It generates an XML which I have bound to a text field on the form. For testing, the field is visible and I can see the XML when I run it.
However the code that I am using to populate the drop down is not working.
I'm ot sure if I have done somethin wrong in the process or in the form.
The XML in the field looks like:
<?xml version="1.0"?>
<xdp>
     <datasets>
          <data>
               <form>
                    <Page1>
                         <type>
                              <assignedOther>
                                   <code>
                                        <CD type="CHAR">ES</CD>
                                   </code>
                                   <code>
                                        <CD type="CHAR">EX</CD>
                                   </code>
                                   <code>
                                        <CD type="CHAR">NF</CD>
                                   </code>
                              </assignedOther>
                         </type>
                    </Page1>
               </form>
          </data>
     </datasets>
</xdp>
In the JavaScript of the form I have:
var parsedOther = new Array();
var taxtypeXML = XMLData.parse(form.Page1.type.assignedOther.rawValue, false);
var otherList = XMLData.applyXPath(taxtypeXML, "//code[*]/CD");
if (otherList.length){
     for (var i = 0; i < otherList.length; i++){
          parsedOther.push(otherList.item(i).value);
}else{
     if (otherList.value){
          parsedOther.push(otherList.value);
parsedOther.sort();
otherExpl.setItems(parsedOther.toString());
assignedOther if the text field that has the XML and otherExpl if the drop down fiend.
