Hi all,
I am generating WebHelp and everything works fine, except "Search" as shown below. Is there any setting to set it right. Can anyone pls help.
Vinay
Looks like you have selected Pure HTML instead of DHTML > Pure HTML in your settings.
If that is not it, what browser are you using?
Hi Vinay,
I'm getting exactly the same issue - using RH10, and I've had to select Pure HTML in order to get webhelp to work in Chrome.
It does now work in Chrome, but unfortunately the Search tab has broken:
Did you find a fix for this?
Cheers,
Andy
How are you viewing the help in Chrome?
Message was edited by Peter Grainge to correct third bullet point.
Hi Peter,
Thanks for responding so quickly.
I'm viewing the help locally using Chrome.
See snippet 3 in the Browsers section of Peter's site at: http://www.grainge.org/pages/snippets/snippets.htm
Hi Colum,
Thanks for that. I'm aware of all the Chrome issues.
Unfortunately I am obliged to provide Webhelp that is to be used locally (it's been fine until Chrome came long).
So now we've started using RH10 because it generates Webhelp that is Chrome compliant by default (or so I thought).
For one of my help systems this is true, however for another it is not.
So I looked at using the pure html option as a work around. All seemed fine until I noticed the search tab as shown above.
Oviously Vinay has had the same problem. So I'm wondering if this is a bug or has there been a work around found for this?
So to summarise - I'm using RH10 to generate Webhelp with the Pure html setting switched on and then deploying locally.
It appears to work fine in Chrome except for the search tab.
I have corrected Post 3 in this thread. Even used locally, webhelp should work fine if it has been generated using Rh10. I just tried it and found it is working fine including the search.
Try trashing the CPD and regenerating without using the Pure HTML option.
Then if still broken try the samples and any other project you have to see if you can pin this on the specific project.
Hi Peter,
I'm sure it's been said before, but anyway you are a saint.
I haven't tested the original issue (posted by Vinay) but this has got me out of a right old fix.
Many thanks.
Cheers,
Andy
