Learn about Edge Delivery Services in upcoming GEM session
SOLVED
Service RepositoryService and operation readResourceContent
Avatar
Former Community Member
When trying to run the application LiveCycle in a Week (Reader Extensions) (Done).lca (Day 2, lesson 2), using LiveCycle Reader Extensions, following error message comes on:
ERROR [com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker] An exception was thrown with name com.adobe.repository.ResourceNotFoundException message:ALC-REP-018-000: Resource [/Applications/LiveCycle in a Week (Forms ES2)/1.0/Assets/current_positions.xml] does not exist or you do not have sufficient rights to access it. while invoking service RepositoryService and operation readResourceContent and no fault routes were found to be configured.
Any hint of what could be wrong?
Thank you.
1 Accepted Solution
Avatar
Correct answer by
Level 2
Hi there,
The value set in the Resource Uri properties of the Read Resource Content activity is pointing to the wrong application. It should be pointing to /Applications/LiveCycle in a Week (Reader Extensions)/1.0/Assets/current_positions.xml.
Chantal
1 Reply
Avatar
Correct answer by
Level 2
Hi there,
Chantal
