How to access the log file in lcds for debugging
Avatar
Level 2
I am wondering what is the procedure to get a log file on lcds for debugging purposes.
+LA
Avatar
Former Community Member
If you want lcds debugging edit /WEB-INF/flex/services.xml and change
the logging parameter to All or Debug
There are filters you can set look under the
Root_dir/resources/config/services.xml for options
Chuckles
Avatar
Level 3
Also, the log output is sent to the console by default. If you want to direct it to a file, you can use the servlet log  target instead of the console target. That will direct the log messages to your app server's log. The setting would look like this in the logging section of services-config.xml:
<target class="flex.messaging.log.ServletTarget" level="Debug">
Here's the doc on serverside logging:
http://help.adobe.com/en_US/LiveCycleDataServicesES/3.1/Developing/WSc3ff6d0ea77859461172e0811f00f70...
