I am working on a Robohelp Project file. This file was earlier upgraded from version 7 to 8. After the upgrade, I had worked on this file to update a few topics, generated the output and everything was working fine, including the links. This update occurred a couple of months ago.
(We have to update this file periodically once a month or so.)
When I tried to open the same file today to include some updates, I see a number of broken links and I am not sure how the Project file which was perfectly fine a few months ago has so many broken links for no rhyme or reason.
Could anyone help me fix this issue please?
Thank you
ACookemane
My guess would be that you have not applied patch 802. See Opening Projects on my site. 802 is a critical update and how to fix the damage done by not applying it is covered in that article.
I will shortly be moving this post to the RoboHelp HTML forum as this forum is for problems with HTML Help - as in CHMs.That may break the link to this thread as we are not sure if a forum problem has been fixed. I will wait until you confirm you have seen this reply, then the thread will move to http://forums.adobe.com/community/robohelp/robohelp_html
Thank you for the response. I will go through the topic that you have recommended
and try the fix.
Thank you
anu
Yes, It worked. I followed your instructions and installed the required updates and the issue was fixed.
Thank you so much for your help.
anu
