Hello.
I have hundreds of jpegs to import over several different captivate projects, and I want them all to import to the same position on the screen. Is there any way to do this, or do I have to manually do each one?
Mike
Hello,
Here is a screenshot of that accordion, highlighted the arrow in yellow, it will open a menu where you can choose Apply to....
Lilybiri
Sorry, I am on a Mac with OS X 10.6.6 running Captivate 5.
Hello,
You will have to put them on different slides, one per slide? It will be manual work, but some tips could help you save time:
Lilybiri
Hello.
It is 1 jpeg/slide, and the slides are all set up with dimensions etc. and are all the same dimensions. I set the first one when I wanted it and moving forward I have manually entered the x and y position points to set the rest.
but, where is the arrow you are talking about in the windows version? i'll check and see if it is there for mac.
-Mike
correction, all slides and all jpegs are set to be the same dimensions
Hello,
Lilybiri
wow do i wish i found that sooner/remembered that. now if i can try your word docs and get it working for the captions i'll be all set.
thanks,
mike
Hi Mike,
It is really too tiny, you'll see a lot of those small arrows in the Properties panel, with each of them you can apply that type of changes to all objects (of same style). It is useful, but for tired eyes difficult to discover
Lilybiri
