Show 2 replies
1. Re: Why does text change color entering multiple terms?
Noel Carboni Apr 13, 2011 6:02 PM (in response to jl2000)I just tried doing just what you described about a dozen times without any color change.
Note that the X key (when not in text editing mode) switches the foreground and background swatch colors... But you didn't say you're seeing them swap, just that the text is the background color.
Are all your drivers up to date (e.g., your display driver)?
Can you reproduce the problem reliably? And if so, does Edit - Preference - Performance, disabling OpenGL Drawing, and restarting Photoshop change this?
-Noel
2. Re: Why does text change color entering multiple terms?
jl2000 Apr 15, 2011 1:38 PM (in response to Noel Carboni)Noel - thanks for the response.
I've taken extra care to see if I can do it predictably and find I cannot. I'm going to go with your suggestion that I was touching the x key hard enough to mke the change and call it "solved".
Thanks again-
JL
