Locked
Export Flash CS5 component to Flash Builder
Apr 17, 2011 Apr 17, 2011
Hello there .
I'm having some troubles exporting a movieClip made in Flash CS5 Professionnal to Flash Builder.
I created a simple movieclip name test : rectangle and textinput inside name "title", then command ->convert symbol for Flex. Everything looks good. I publish the .swc and import it in Flash Builder.
Everything is good when I just add the MovieClip :
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
   xmlns:s="library://ns.adobe.com/flex/spark"
   xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:local="*">
<local:test />
</s:Application>
but when I try to set a value to the title <local:test title="Title" />, I get the following error : (sorry it's in french =O)
Description Resource Path Location Type
Initialiseur pour 'test' : les valeurs du type flash.text.TextField ne peuvent pas être représentées dans le texte. TestComponent.mxml /TestComponent/src line 5 Erreur Flex
Google translate:
Initializer for 'test': values ​​of type flash.text.TextField can not be represented in the text.TestComponent.mxml / TestComponent / src line 5 Error Flex
There are a lot of tutorial showing how to integrate Flash Builder & Flash Cs5 but not so much tutorial about how you can import Flash CS5 component into Flash builder 😕
Hope you can help me
480
Nevermind stupid question
title points on TextField and not on .text property... of course -.-
