When I run the Project Template Generator script I get the following error. Can someone tell me what this is?
Thanks for your help!
Without looking into the script code I'd second guess that there is an issue with it at line 49
Are you referring to the Save As Project Template script? It runs OK for me. Was the script changed in any way before running it?
The RoboColum(n) | @robocolumn | Colum McAndrew |
I didn't change anything. Just running it "out of the box". I don't know anything about scripting, so doubt whether I can decifer the problem myself by looking at the script.
This is the code on line 49:
RoboHelp.project.rename("Template.xpj");
I'm using RoboHelp 9. It's called Project Template Generator.jsx.
Yep. It runs fine for me. I assume you have a project open when you run it? Can you run any macro (e.g. Word Count)?
Hi Colum,
Yes, Word Count seems to work fine.
Just a thought, does your project have any special characters in the name (e.g. underscores / slashes). That maybe could be the issue. If it doesn't, try reinstalling the ExtendScipt add on.
Extendscript is working fine on your machine. Project Template Generator script requires administrator rights as it tries to create template in program files folder area. For this reason please try to run RoboHTML in adminstrator mode. If you are using windows vista or windows 7, you can select run as administator by right clicking the RoboHTML shortcut. If you are running windows XP then you need adminstrator rights.
Do let me know if this fixes the error on script running or not.
Praful jain
I hadn't had the time to update the thread, but this was indeed the problem!! Thank you for your reply.
What was the answer? There is more than one reply.
Sorry. The answer was that I needed Admin rights to run the script.
