Locked
How to update FlashBulder 4 to FlashBuilder Buritto?
Nov 14, 2010 Nov 14, 2010
Hello!
I have installed FlashBulder 4 as standalone and I activated him.
Can I install Butitto without removing the FB 4?
Do I need to deactivate FB4 before installing Buritto?
Do I need to uninstall FB4 before installing Buritto?
Installation and activation
843
Hello,
Flash Builder 4 is the currently released version, and Burrito is a Preview (Beta) version, that can be installed alongside FB4. There's no need to uninstall FB4 before installing Burrito, or vice-versa.
They install into separate locations by default, and will run independently from one another. Licensing is also independent - Burrito will run in its own trial period until you activate it with a serial number. You can use your FB4 SN to activate Burrito, without affecting your existing FB4 activation.
-Chris
Apr 18, 2011 Apr 18, 2011
will FB4.5 be a chargeable upgrade from FB4? And I currently use FB4 alongside Dreamweaver (for PHP coding only) -  will there be an upgrade path from that combination to FB4.5 for PHP?
Guest
Apr 19, 2011 Apr 19, 2011
I'm having troubles activating Buritto.. I was able to get a new serial for Paninni.. and the site says too follow the same process for Burrito.. I do, and get the same serial which does not work..
Any ideas?
I called customer support and they said to post here..
Todd
Adobe Employee ,
What is the error message you are seeing when you enter the serial number?
Can you please send me amt3.log and oobelib.log files? They are located under %temp% in win and /tmp in Mac.
Also may I know which burrito build you are using and how you obtained the serial number?
Please mail the details to me at deeptika (at) adobe (dot) com.
Deeptika
