1. Re: Every time PS opens it says Application has moved
charles badland Apr 22, 2011 9:17 AM (in response to rlinsurf1)Every time PS opens it says Application has moved
Has it been moved?
The CS5 Photoshop App should reside in the CS5 Photoshop folder which should reside in the Applications folder.
(from Finder Go>Applications>Adobe Photoshop CS5 folder>Adobe Photoshop CS5 application)
2. Re: Every time PS opens it says Application has moved
rlinsurf1 Apr 22, 2011 10:28 AM (in response to charles badland)No, that's exactly it's location. However, another odd thing is that sometimes when I choose Open using.. from the Finder, it finds and opens the second copy of PS on my backup drive, and then I have two copies of PS open. But again, that's the same situation for all the other CS5 apps.
3. Re: Every time PS opens it says Application has moved
Marian Driscoll Apr 22, 2011 11:35 AM (in response to rlinsurf1)rlinsurf1 wrote:
...it finds and opens the second copy of PS on my backup drive, and then I have two copies of PS open...
You are likely confusing things by having two installations of Photoshop accessible to the system, even if you are not running the backup installation.
Consider storing your backup system remotely. Mirror the system once a month or so and then disconnect the drive and store it somewhere else. Right now, you're only protecting yourself from a primary drive failure. Your connected backup drive does not save you from theft/fire/tsunami, where it would be damaged/lost along with your primary drive.
4. Re: Every time PS opens it says Application has moved
rlinsurf1 Apr 22, 2011 12:10 PM (in response to Marian Driscoll)Hi, Marian--
I can't. The backup drive is internal. (I know, that doesn't protect me from a flood, but my backups are because I have 4 Hard Drives die on me
5. Re: Every time PS opens it says Application has moved
Marian Driscoll Apr 22, 2011 1:20 PM (in response to rlinsurf1)rlinsurf1 wrote:
...The backup drive is internal.Oh. Is it one of those that are soldered in?
6. Re: Every time PS opens it says Application has moved
rlinsurf1 Apr 22, 2011 1:22 PM (in response to Marian Driscoll)lol
