2 Replies Latest reply: Apr 23, 2011 12:11 PM by barpos RSS
    Error on abode webpage
    barpos Community Member
      http://www.adobe.com/devnet/flash/articles/as3_debugger.html
      The code provided for the second sample .FLA file does not work.  There's something missing, as one needs to instantiate the custom class.  I also tried to do that, but failed.  I'm at loss here.
      StringUtils.reverse("Flash CS3 makes debugging fun!");
        • 1. Re: Error on abode webpage
          Lee Burrows Community Member
          hi
          you need to save:
          package {
                public class     StringUtils {
                     public     function StringUtils() {}
                    public static     function reverse(s:String):String {
                          var     tmp_array:Array = s.split("");
                          tmp_array.reverse();
                          var     tmp_string:String = tmp_array.join("");
                         return     tmp_string;
          as "StringUtils.as" in same folder as your fla file
          • 2. Re: Error on abode webpage
            Ah, I had already saved the .AS file, but didn't bother saving the UNTITLED.FLA file. It works now!
            Ron
