Adobe Community
All community
This category
This board
Knowledge base
Users
cancel
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results forÂ
ShowÂ
 onlyÂ
Search instead forÂ
Did you mean:Â
Global community
Language:
Deutsch
English
Español
Français
Português
日本語コミュニティ
í•œêµ ì»¤ë®¤ë‹ˆí‹°
Sign In
Home
ColdFusion
Discussions
import to mysql using coldfusion
Home
ColdFusion
Discussions
Upvote
Guest
/t5/coldfusion-discussions/import-to-mysql-using-coldfusion/td-p/1045002
Jul 23, 2006
Jul 23, 2006
Hi is there a way of uploading a excel sheet into mysql that has the same column names has my mysql database using coldfusion?
its a simple format with
firstname, surname, phonenumber
Advanced techniques
557
Follow
More
Reply
Reply
Be kind and respectful, give credit to the original source of content, and search for duplicates before posting.
Learn more
3
Jump to latest reply
jfillman
Contributor
/t5/coldfusion-discussions/import-to-mysql-using-coldfusion/m-p/1045003#M94433
Jul 24, 2006
Jul 24, 2006
If you do a Google search on Excel to MySQL, you should find some applications that will do this for you.
Upvote
Follow
More
Reply
Reply
Learn more
paross1
Mentor
/t5/coldfusion-discussions/import-to-mysql-using-coldfusion/m-p/1045004#M94434
Jul 24, 2006
Jul 24, 2006
I suppose that you could create an ODBC datasource with your Excel file, create theColdFusion DSN, then query your spreadsheet "table" like any other database, where you could then loop through the output and insert the rows into a MySQL table.
Dynamic data sources in ColdFusion MX
Phil
Upvote
Follow
More
Reply
Reply
Learn more
webpointz
New Here
/t5/coldfusion-discussions/import-to-mysql-using-coldfusion/m-p/1045005#M94435
Jul 25, 2006
Jul 25, 2006
Try Intelligent converters...I've used their products before and it's quick and clean.
http://www.convert-in.com/xls2sql.htm
Upvote
Follow
More
Reply
Reply
Learn more
Post Reply
Preview
Exit Preview
never-displayed
You must be signed in to add attachments
never-displayed
Â
Documentation
ColdFusion User Guide
