Show 3 replies
1. Re: Set a particular file to default to print markup
MichaelKazlow Apr 24, 2011 8:03 AM (in response to CharlesBelov)I do not think you can.
2. Re: Set a particular file to default to print markup
jallisy Apr 24, 2011 8:52 PM (in response to CharlesBelov)You may try using the Preflight Tool to "Flatten" the image. I don't know
exactly the process behind the technology but it will flatten the annotation
layer of the pdf to the main layer and the comments.
Another alternative may be to print the pdf with the annotations selected
(make sure in Preferences/Commenting the option is set to print notes and
popups) and distribute the resulting file.
3. Re: Set a particular file to default to print markup
CharlesBelov Apr 25, 2011 3:23 PM (in response to jallisy)Yes, using Preflight > Flatten annotations gives the most desired result. The other way works as well (that's what I wound up doing before I got your answer) but produces a much larger file.
