I've been trying to use the MS tool shutdown.exe to reboot a
remote server. Works fine from command line, but when I put it in a
cfexecute it does not. Blow is the cfexecute code and the results
from the output file.
All ColdFusion code and process will run with full admin
rights and
privileges, passing this on to the users of these CF
applications.
It is a better practice to create a CF user with just the
rights it
needs to run the applications being built on that server.
That is what
we do here.
jleblond wrote:
> OK - I changed the CF service to run as an admin user -
that worked. THANK YOU
> What (if any) is the downside to running CF as an admin
user rather than as local system?
Agreed. Assume that you've got a hole, bug, etc., so your
error or somebody's intentional action could be very damaging,
since you gave to CF rights to do anything...
