problem regarding FlashVars
Apr 27, 2011 Apr 27, 2011
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en">
<head>
<title>flashVarsTests</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<style type="text/css" media="screen">
        html
, body { height:100%; background-color: #ffffff;}
        body
{ margin:0; padding:0; overflow:hidden; }
#flashContent { width:100%; height:100%; }
</style>
</head>
<body>
<div id="flashContent">
<object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" width="550" height="400" id="flashVarsTests" align="middle">
<param name="movie" value="flashVarsTests.swf" />
<param name="quality" value="high" />
<param name="bgcolor" value="#ffffff" />
<param name="play" value="true" />
<param name="loop" value="true" />
<param name="wmode" value="window" />
<param name="scale" value="showall" />
<param name="menu" value="true" />
<param name="devicefont" value="false" />
<param name="salign" value="" />
<param name="allowScriptAccess" value="sameDomain" />
<param name="flashvar" value="message1=HelloWorld" />
<!--[if !IE]>-->
<object type="application/x-shockwave-flash" data="flashVarsTests.swf" width="550" height="400">
<!--<![endif]-->
<a href="http://www.adobe.com/go/getflash">
<img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash player" />
</a>
<!--[if !IE]>-->
</object>
<!--<![endif]-->
</object>
</div>
</body>
</html>
above code is the generated html.
I use Flash Professional CS5 Actionscript 3.0
Here's the code in my Flash file
if(root.loaderInfo.parameters["flashvars"] != null){
    myText.text = root.loaderInfo.parameters["flashvars"];
Just trying to display the flashvars on to the stage with the text named myText
By the way this part <param name="flashvar" value="message1=HelloWorld" /> I only put this after generating the html file through flash.
Any response is greatly appreciated.
ActionScript
964
LEGEND , Apr 27, 2011 Apr 27, 2011
I don't think you are accessing/testing the correct things.  Try changing yourFlash code to...
var params:Object = LoaderInfo(root.loaderInfo).parameters;
if(params != null){
    myText.text += String(params["message1"]);
Just a quick noticing that you use both "flashvars" versus "flashvar"
versus
Ops! my fault...
I already fix that typo error still didn't work.
By the way I use flash player 10.
if(params != null){
I already apply the code still didn't work. I used Flash Professional CS5 and flash player 10.
result is undefined.
got it fixed.
Thanks.
You're welcome
