Flash Builder 4 trace problem.....
I got the trace-classical problem:
267 AVMINF: MTHD global$init ()
267 AVMINF: MTHD flash.display::Sprite$cinit ()
267 AVMINF: MTHD flash.display::MovieClip$cinit ()
267 AVMINF: MTHD PreloaderDisplay$cinit ()
267 AVMINF: MTHD mx.managers::SystemManager$cinit ()
267 AVMINF: MTHD flash.utils::Dictionary$cinit ()
267 AVMINF: MTHD flash.utils::Dictionary ()
267 AVMINF: MTHD flash.utils::Dictionary/init ()
79 AVMINF: MTHD flash.display::Loader/get contentLoaderInfo ()
379 AVMINF: MTHD flash.events::EventDispatcher/addEventListener ()
379 AVMINF: MTHD flash.display::Loader/loadBytes ()
380 AVMINF: MTHD flash.display::Loader/_buildLoaderContext ()
380 AVMINF: MTHD flash.display::Loader/_getJPEGLoaderContextdeblockingfilter ()
380 AVMINF: MTHD flash.display::Loader/_loadBytes ()
More information:
*I did read many answer already about the mm.cfg file, but I don't have that file, i don't even got firefox...
*That is happens only when i am using flash player 10.2 + (IT DOES NOT HAPPENS WITH FLASH PLAYER 10.1 - )
Please help,
Thanks for advance.
Esteban
Low level method tracing seems to be enabled.
Read http://livedocs.adobe.com/flex/3/html/help.html?content=logging_04.html and re-confirm you don't have mm.cfg in any of the locations listed.
No, i am not.
What other files the 'flash-tracer for firefox' is realeted?
The problem start when i did install it.
I did the update it, and does not goes away. I did uninstall the entire firefox, and did not goes away.
I did uninstall the flash player and then i just pay attention that is goes away with flash player version untill 10.1.
Any idea?
Can you check if mm.cfg is present for the admin user? (Or whatever user Firefox was installed with (probably elevated to admin)).
Another thing to consider is the virtual per user temporary filesystem mapping that Vista/Win7 does. Try going to C:\Users\User_name\AppData\Local\VirtualStore\ and see which files are present there.
