I am interested in using Robohelp 9 as my single source to make both HTML help (.chm) and print documentation (PDF). I had hoped to use .tif files as my source images for the single source so that i can have the best print quality images when rolling out the PDF format. However, the Robohelp 9 user guide indicates that you can only add an image to a robohelp topic in the following formats:
http://help.adobe.com/en_US/robohelp/robohtml/WS9B67D0AF-955F-416e-9556-A2A062BB2037.html
gif and jpeg is obviously not a good option for print projects and It seems to me that only allowing .bmp format for single source project to pdf is not such a good option either.
Please advise about whether i am correct that i cannot use .tif and also advise about what the consequences are of using BMP instead for PDF.
Any guidance about images in regards to Robohelp 9 single source to PDF would be appreciated. Thank you.
Quite simply RoboHelp does not support TIFF. I guess the reason is you would not use that format in online help because of the file size. BMP's are supported but are not generally used in online help, again because of file size.
I cannot comment on BMPs going to PDF as I don't use them, reason above.
Like most RoboHelp users I work with JPG and GIF images and get satisfactory results both online and in print. PNG images are also an option.
My concern is not about using .tif or .bmp for HTML help (gif and jpeg are for html). My concern is about using robohelp for single source project where I will be publishing to print documentation where i will need higher quality resolution for the images.
Hopefully someone with knowledge about print quality images and single sourcing experience can give me some advice.
RoboHelp does not support TIFF images regardless of output, online or print. That was one of your questions and I have answered that.
Have you tried the supported options to see how well RoboHelp deals with them?
I have a feeling that with some online outputs BMPs get converted to another format, you can check that.
I would appreciate some help from someone familiar with using the same source images when generating both html and printed documents from robohelp (single source to print pdf).
Jeff
I surrender. I said in my first post "Like most RoboHelp users I work with JPG and GIF images and get satisfactory results both online and in print. PNG images are also an option."
You have said "gif and jpeg is obviously not a good option for print projects". Why is it obvious? Unless you are talking about the very highest quality documents produced by a professional printing company, then RoboHelp generally gives good results in documents sent to Word.
I'll leave this to someone else but perhaps if you describe the problem you are having with jpg and gif images, it will help.
I am also in the process of single-sourcing my content for both PDF and online help (Webhelp in my case).
I have found that I have acheived the most satisfactory results with gif files. Most of my images are screen captures. I save as gif when I capture the images, and they seem to print quite nicely, and look good online, too.
I recently posted my results in the "FrameMaker integration" area of the Robohelp forum.
Sue
