7 Replies Latest reply on Apr 30, 2011 1:39 PM by crmark
    sata 6.Gbps drives
    crmark Level 1
      My intel dp67bg extreme mobo has Two Serial ATA (SATA) 6.0 Gb/s interfaces and Four internal SATA 3.0 Gb/s interfaces.
      Should I look for samsung drives that have high transfer rates. Would it be wise to put two of these on RAID 0?
      How will they compare to WD velociraptors @10k rpm?
        • 1. Re: sata 6.Gbps drives
          JCschild Level 3
          for the most part you can ignore it the benchmarks differnce between Sata 600 and 300 is non existant
          however if buying new drives you want 64meg cache which pretty much means sata 600 at this point.
          Raid 0 is great but you need 2 equal sets
          Raptors(new ones) will give better performance but may be over kill and the differences are not all that much
          here are some benchmarks
          WD 1 TB 64 meg Cache Sata 600 Drives
          Intel onboard Controller
          Single drive - 112MB
          2 Drive Raid 0 - 196MB
          4 Drive raid 0 - 364MB
          3 Drive Raid 5 - 108MB
          4 Drive Raid 5 - 296MB
          Marvell 6G controller
          Single Drive  - 111MB
          2 Drive Raid 0 - 215MB
          Intel SAS RS2BL080 8 Port controller with 512 DDR2 Ram.
          4 Drive Rqaid 0 - 429MB
          3 Drive Raid 5 - 219MB
          4 Drive Raid 5 - 315MB
          Seagate 1TB 32 Meg Cache Drives
          Onboard Intel Controller
          Single Drive - 103MB
          2 Drive Raid 0 - 206MB
          4 Drive Raid 0 - 395MB
          3 Drive Raid 5 - 202MB
          4 Drive Raid 5 - 299MB
          Single Drive - 101MB
          2 Drive Raid 0 - 199MB
          4 Drive Raid 0 - 399MB
          3 Drive Raid 5 - 204MB
          4 Drive Raid 5 - 310MB
          Intel SAS RS2PI080 8 Port controller with 512 DDR2 Ram
          8x WD VelociRaptor 600 GB, SATA 6 Gb/s, 32 MB Cache, 10,000 RPM
          8 Drive Raid 5 - 745MB/s read 735MB/s Write
          8x WD 1TB SATA 6 Gb/s, 64 MB Cache, 7200 RPM
          8 Drive Raid 5 - 703.8MB/s read 670MB/s Write
          Scott
          ADK
          1 person found this helpful
          • 2. Re: sata 6.Gbps drives
            crmark Level 1
            Wow thank Scott.
            I presently have 1 WD velociraptor 150GB @10k rpm. Im a little slow...
            For instance when you say "
            Does it mean you get a speed of 112MB/s or are you mentioning what GB drives should be combined together on RAID?
            • 3. Re: sata 6.Gbps drives
              JCschild Level 3
              those are the measured benchmarks for the listed drive configs
              • 4. Re: sata 6.Gbps drives
                Bill Gehrke Most Valuable Participant
                Scott, I assume that the single number is the read speed and the you are using HD Tune Pro for the benchmarks--is that correct?  It appears that a 32 GB Seagate is slightly faster than the 64 GB WD.
                • 5. Re: sata 6.Gbps drives
                  crmark Level 1
                  So I took Bills advice and got myself 2x 1TB HDDs with 32MB cache that run at 7200RPM, I also have 1x WD velociraptor 150GB HDD that runs at 10000RPM.
                  Im wondering what would be better? leave my WD HDD as the boot drive and run the other two in RAID 0?
                  Also I haven't opened up a CPU ever, I'm wondering which ports I should plug them in to get them to work at RAID 0 before I enter BIOS? My baord the intel DP67BG has 4 SATA ports  (3.Gbps ) and 2 SATA ports that are (6 GBPS).
                  Mark
                  • 6. Re: sata 6.Gbps drives
                    JCschild Level 3
                    Raptor as OS
                    Again you need 2 x raid 0 sets  or 2 non raid drives.
                    You never want to read and write from the same drive(s) unless it’s a 8+ drive array
                    Scott
                    • 7. Re: sata 6.Gbps drives
                      crmark Level 1
                      Thanks again Scott. So I've installed my Drives, set them up as RAID.
                      I had to install WIN 7 again, it crashed for some reason when I added 8GB RAM and the drives.
                      SO C drive is my 150GB Velociraptor.
                      Ive set up the other drives but WIN 7 hasn't recognised them. I'm installing all the updates. I should hopefully be able to see them after the updates are installed.
                      Question now is when I run AE & PREM. Which drive should I use as scratch disk? Which drive do I save my files in? Which drive do I export the output to?
                      Mark
