I am using groupField in Advanced Datagird, in that i want sort the date field. The date field sees like that 06/22/1986(Month/Date/Year). How i can sort it.
Sivabharathi
(Sorry for the bad formatting, text only mail conversion)
There are a few ways off the top of my head to modify the sort behavior.
1. If the data is string based date, change the format to be YYYY/MM/DD. This will allow it to string sort it.
2. The DataGridColumn has a sortCompareFunction you may create your own compare function using the ObjectUtil dateCompare function which returns similar values required by the
http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/mx/controls/dataGridClasses/DataGridColumn.html#sortCompareFunction
mySortCompareFunction(obj1:Object, obj2:Object):int
The function should return a value based on the comparison of the objects:
• -1 if obj1 should appear before obj2 in ascending order.
• 0 if obj1 = obj2.
• 1 if obj1 should appear after obj2 in ascending order.
http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/mx/utils/ObjectUtil.html#dateCompare()
dateCompare(a:Date, b:Date):int
3. Add sorting to the dataProvider such as an XMLListCollection or an ArrayCollection. They have both filterFunction and a sort function support.
http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/mx/collections/ListCollectionView.html#sort
Setting the sort does not automatically refresh the view, so you must call the refresh() method after setting this property
http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/mx/collections/Sort.html
Using the mx.collections.sort
Hope this helps a little
Thank you for your reply. I tried sortComparefunction. But it's not working perfect. Look at the example.
<?xml version="1.0" encoding="utf-8"?>
<!-- http://blog.flexexamples.com/2007/08/12/sorting-date-columns-in-a-datagrid/ -->
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
<mx:Script>
<![CDATA[
import mx.collections.XMLListCollection;
import mx.events.FlexEvent;
import mx.utils.ObjectUtil;
public var reportXMLList:XMLList = new XMLList();
public var listCollection:XMLListCollection ;
private var tempXML:XML ;
private function date_sortCompareFunc(itemA:Object, itemB:Object):int {
var dateA:Date = new Date(Date.parse(itemA.dob));
var dateB:Date = new Date(Date.parse(itemB.dob));
return ObjectUtil.dateCompare(dateA, dateB);
protected function init():void
tempXML = new XML(<root>
<row col1="12/27/2010"/>
<row col1="12/29/2010"/>
<row col1="01/05/2011"/>
<row col1="01/07/2011"/>
<row col1="01/31/2011"/>
<row col1="02/15/2011"/>
<row col1="02/17/2011"/>
<row col1="02/18/2011"/>
<row col1="02/25/2011"/>
<row col1="03/11/2011"/>
<row col1="03/18/2011"/>
<row col1="03/19/2011"/>
<row col1="03/21/2011"/>
<row col1="03/22/2011"/>
<row col1="03/26/2011"/>
<row col1="03/30/2011"/>
<row col1="03/30/2010"/>
<row col1="03/30/2009"/>
<row col1="03/30/2015"/>
</root>);
reportXMLList = tempXML.row;
listCollection= new XMLListCollection(reportXMLList);
</mx:Script>
<mx:AdvancedDataGrid id="dataGrid" initialize="init()" dataProvider="{listCollection}"
width="100%" height="100%">
<mx:groupedColumns>
<mx:AdvancedDataGridColumn dataField="@col1"
headerText="Date of birth:"
sortCompareFunction="date_sortCompareFunc"
</mx:groupedColumns>
</mx:AdvancedDataGrid>
</mx:Application>
Ok I found a couple of corrections for you. I tried to keep everything formatted the same.
Added a binding to the dataProvider.
[Bindable]
And your sort function seems to be trying to load a child node called "dob" that doesn't exist. It needs to load your property for the row node called "@col1".
var dateA:Date = new Date(Date.parse(itemA.@col1));var dateB:Date = new Date(Date.parse(itemB.@col1));
Seems to work now. On a side note, an advanced datagrid seems to add about 100k more compiled than a regular datagrid.
Thank for your reply. It's really helps for me.
Here your given itemA.@col1 as static. But i my report date field will come any place like
1) <row col1="01/05/2011" col2="a"/>
2) <row col1="b" col2="01/05/2011" />
3) <row col1="c" col2="2" col3="01/05/2011" />
Because my report is not static column. It's dynamic, so date field will come any place (col1, col2 or col3). Then how i can give the itemA.@col1.
Sorry, I cant understand your note.(An advanced datagrid seems to add about 100k more compiled than a regular datagrid.)
Sivabharathi.
I believe each DataGridColumn uses its own sortCompareFunction. I see it does not allow additional values to be passed other than the two row objects. You may need to create a new sortCompareFunction for each column. Would that fix the column naming maybe?
For the note, the AdvancedDataGrid is a larger component. It has a few extra features such as grouping. But when I looked at the swf file size difference between the advanced and the regular it was 100k file size difference for me.
Thank you for your reply. If any other way there to assign values like this.
Var value1:String = new String("col1');
Var value2:String = new String("col1');
var dateA:Date = new Date(Date.parse(itemA.@+"value1"));
var dateB:Date = new Date(Date.parse(itemB.@+"value2"));
It's not a possible each to create one method for each column. Because my report is dynamic, the column will increase or decrease. So i cant recreate method for all the columns. I want one method it's supports all the columns. How i can do this.
Sivabharathi
