When trying to import a project that is on a network path, I get: An internal error occurred during: "Importing projects.". java.lang.NullPointerException. The only way around it is if I delete the project files and re-create the project. However, then when I go on my other workstation, I need to re-import the project again since it had been changed and again, "Importing projects" has encountered a problem.
According to the updater in CFBuilder, there are no updates available so I'm at the latest version on both.
Is the project fairly big? I got this sort of thing with the initial release of CFB all the time. It was improved after that initial bugfix patch, but was not completely resolved.
Adam
I had the same issue on Win XP/CFBuilder Version: 2.0.0 ; Build: 277745.
I changed ".project" (cfeclipse project file) file from
<projectDescription>
<name>CADES 2009 (components)</name>
</projectDescription>
to
<name>CADES 2009 [components]</name>
I had this exact same problem and this fix worked! Why doesn't it work when there are parentheses in the project name?
--Stewart
