I was going to open up a bug in the adobe bug list, but before I did that I wanted to double check with the forums.
We have a lot of old flex3 projects that make a connection to our SOAP services. To generrate the .wsdl files for these services we use an old program called XFire. http://xfire.codehaus.org/Download We are using version 1.1.1
In Flex Builder 3 (which we sadly still have to use) we are able to generate the code for the SOAP services, using the wizard perfectly. Everything works fine.
However, when I tried to get the office to upgrade to Flash Builder 4, we discovered that our .wsdl files can not be converted. The error we recieve is:
There was an error during service introspection.
src-resolve.4.2: Error resolving component 'ns1:Vidget'. It was detected that 'ns1:Vidget' is in namespace 'http://model.tvhive.attractv.com', but components from this namespace are not referenceable from schema document 'http://services.attractv.net/newtvhive/services/VidgetServiceImpl?wsdl'. If this is the incorrect namespace, perhaps the prefix of 'ns1:Vidget' needs to be changed. If this is the correct namespace, then an appropriate 'import' tag should be added to 'http://services.attractv.net/newtvhive/services/VidgetServiceImpl?wsdl'.
Can you file it at http://bugs.adobe.com/flex under
Flex Builder / Flash Builder category.
-Sunil
Ok, I created the bug here:
https://bugs.adobe.com/jira/browse/FB-30959
Let me know if I should change or add anything to the bug report.
it may be the issue that i had
add a reference nulling out w3.org
otherwise it would be a real problem with your service
can you provide a url link to your wsdl for a sanity check ?
There was a url in the original post: Here http://services.attractv.net/newtvhive/services/VidgetServiceImpl?wsdl
sorry missed that
here is mine
http://50.19.125.248/greeter03?wsdl
yours looks a bit blank even compared to mine !
For your URL I get a different error than I get for mine.
On yours I got:
WSDLException (at /wsdl:definitions/wsdl:types/xsd:schema): faultCode=OTHER_ERROR: An error occurred trying to resolve schema referenced at 'http://dbsvr/greeter03?xsd=xsd1', relative to 'http://50.19.125.248/greeter03?wsdl'.: java.net.UnknownHostException: dbsvr
which version of flex or flashbuilder are you using. sorry if you already stated it.
i am using FB4 release
my wcf is written in Visual Studio 2010 c#
I'm using both FB4 premium, and the new FB4.5 release, same result in both.
If you look closely at the error I posted, I think you will see that its trying to access some database that I don't have permision to access, or it can't find. Not 100% on that.
