I am getting the following error message when I try invoking
a webservice.
Could not generate stub objects for web service invocation.
https://clientaccweb.reseaudistinction.com/CardHolderInfo.asmx?WSDL.
org.xml.sax.SAXException: Fatal Error: URI=null Line=11: The
element type "META" must be terminated by the matching end-tag "".
It is recommended that you use a web browser to retrieve and
examine the requested WSDL document for correctness. If the
requested WSDL document can't be retrieved or it is dynamically
generated, it is likely that the target web service has programming
errors.
The problem is, the webservice is working fine, the
application was working yesterday, the error message just appears
after a couple of days and I have to refresh the service in the CF
Administrator. Once I refresh it, everything starts working again.
Anyone else got this problem? ANY help would be appreciated!
If you guys need my code anyway, I can attach it but like I
said, everything works for a couple of days, then, out of the blue,
it stops working so I doubt that it's my CFINVOKE that's the
problem...
