Hello,
Who can help? I recently upgraded from Adobe Acrobat Reader 9 to Adobe Reader X. Since then, a strange problem occurs. When printing a pdf files to a printer, the font is changed. When viewing the file on the screen and printing them with version 9, everything is OK. The Arial font appears as it should. But when printing, a very ugly font type appears. The pdf files I use contain only a 'standard' Arial and Myriad Web font.This problem is very annoying.
Can somebody help? I use version 10.0.1
I have the same problem. I have read that there is a problem with Reader 10 X and HP printers. It prints some PDF files (Randomly) in a strange language, may be greek or something. I have removed reader X from my computer and downloaded Reader 9 until this problem is resolved.
Doesn't seem a small issue to me. The printed output differs substantially from the pdf file. Shouldn't it have been repaired yet? I don't think I'm the only one with this problem.
By the way, version 9 cannot be found anywhere.
If you go the attached web page:
http://www.adobe.com/support/reader/
(http://www.adobe.com/support/reader/) , you
will see "download an older version" underneath
the Download Adobe reader.
If you click in this link (download an older version), you
can pick from version 8 and 9.
Since erasing version 10 and downloading version 9.4,
my problem has gone away completely.
As with you, I consider this a major problem. It certainly added
a lot of grief to my life when I could not trust my printer
output at all.
Hope this helps.
Marsha
Thanks for your hint. I deinstalled Reader X and installed Reader 9.4 again. Now, the problem is solved and the output is as it shoul be.
Igor
I actually got the idea from another person who responded
on the forum. The forum is helpful as you get good information
from others.
Best of luck.
I have the identical problem not with the HP printer but with a CANON MX7600. Please inform, when a solution for Reader X is available. I'll go back to the older version.
Same problem. Will go back to version 9.4, but really disappointed.
Hope the bug is fixed soon.
Went back to 9.4 but had the same problem, so have reinstalled 10. So, maybe there is something wrong with the fonts on some web pages? The page I am trying to print to pdf prints out OK on my canon printer and displays OK on the web page, but printing to pdf makes most of the fonts, not the headings, appear as an alien language. The page has a print icon on it and I used that to print.
I worked around the problem by selecting all the text and pasting it to a Word Docx. Printing that to a pdf worked just fine, but obviously the page does not look the same as it just has the words and not the appearance.
Am I doing something wrong or does printing to pdf have this happen sometimes.
