1 Reply Latest reply: May 3, 2011 2:42 PM by barpos RSS
    transition manager problem
    barpos Community Member
      After I run the following code,
      industriesTM.startTransition({type:Blinds, direction:Transition.OUT, duration:3, easing:None.easeIn, numStrips:25, dimension:0});
      I later have this [non-working] code:
      industriesTM.startTransition({type:Blinds, direction:Transition.IN,  duration:3, easing:None.easeIn, numStrips:25, dimension:0});
      Each of the snippets above are located in different listeners.  The first snippet in an Over button listener, and the second within a Click listener.
      What am I doing wrong?
      Regadrs,
      Ron
        • 1. Re: transition manager problem
          Ok, I separated the two lines of code, one associated to an Over state
          button and the other with another button.  It seems like once the display objects are faded out, there's no way to fade them back in.
          Is there a way to reset things before fading in?
          Regadrs,
          Ron
