I keep getting this error TypeError: Error #1034: Type Coercion failed: cannot convert views::EmployeesNonAvailsInnerClass2@3717c29 to mx.controls.listClasses.IListItemRenderer. When I select the column which the dropdownList is suppose to display. I am using a custom component which I included the code below. I am new to Flex and so what I have so far came out of the book Flex 4 Bible. My data is coming from a webservice and returns an array of class ReasonDto and I am saving the results to a s:ArrayCollection. I sorta had it working before the custom dropdownlist when I used mx controls but I keep getting this when I use s controls. Any suggestions?
package components
import mx.events.FlexEvent;
import spark.components.DropDownList;
public class SelectableDropDown extends DropDownList
public var selectField:String = "";
public var selectFieldValue:* = null;
public function SelectableDropDown()
super();
this.addEventListener(FlexEvent.CREATION_COMPLETE, creationCompleteHandler);
private function creationCompleteHandler(event:FlexEvent):void
updateSelection();
public function updateSelection():void
if (selectField != "" && selectFieldValue != null && dataProvider != null)
var dataObj:Object;
for (var i:Number=0; i<dataProvider.length; i++)
dataObj = dataProvider.getItemAt(i);
if (dataObj[selectField] == selectFieldValue)
selectedIndex = i;
break;
Here is the code which calls the component
<mx:DataGridColumn headerText="Reason" width="100" dataField="reason.reason" editable="true"
editorDataField="selectedItem">
<mx:itemEditor>
<fx:Component>
<components:SelectableDropDown prompt="Select a Reason"
dataProvider="{parentDocument.reasonsDP}"
labelField="reason.reason"
selectField="reason"
selectFieldValue="reason.reason"/>
</fx:Component>
</mx:itemEditor>
</mx:DataGridColumn>
The answer was to just add the canvas and that solved it. Still having issues but this is the solution to this problem
Here is my current code now
<mx:itemEditor>
<fx:Component>
<mx:Canvas>
<fx:Script>
<![CDATA[
import mx.collections.ArrayCollection;
import mx.rpc.events.ResultEvent;
import mx.controls.Alert;
[Bindable]
public var reasonsDP:ArrayCollection;
protected function sdd_creationCompleteHandler(event:FlexEvent):void
getReasonsResult.token = personnelBean.getReasons();
public function get selectedItem():ReasonDto
return selectableDropDown.selectedItem;
public function get prompt():ReasonDto
return selectableDropDown.selectedItem.reason;
<!-- public override function setFocus():void
selectableDropDown.setFocus();
protected function getReasonsResult_resultHandler(event:ResultEvent):void
reasonsDP = getReasonsResult.lastResult;
</fx:Script>
<fx:Declarations>
<personnelbean:PersonnelBean id="personnelBean" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
<s:CallResponder id="getReasonsResult" result="getReasonsResult_resultHandler(event)"/>
<valueObjects:ReasonDto id="reasonDto"/>
<!-- Place non-visual elements (e.g., services, value objects) here -->
</fx:Declarations>
<components:SelectableDropDown id="selectableDropDown"
dataProvider="{reasonsDP}"
labelField="reason"
selectFieldValue="reason"
creationComplete="sdd_creationCompleteHandler(event)"/>
</mx:Canvas>
</fx:Component>
</mx:itemEditor>
See my second post to this question
