Locked
6
Adobe Flash Player 10 ActiveX and Adobe Flash Player Plugin
Guest
May 04, 2011 May 04, 2011
Windows 7 64bit / IE8
I uninstalled Adobe Flash Player 10 ActiveX and Adobe Flash Player Plugin thinking they would be reinstalled together when I installed the latest version of Adobe Flash Player.
Now I only see the entry for Adobe Flash Player 10 ActiveX 10.2.159.1 listed in - Uninstall or change a program.
I was wondering how to get the Adobe Flash Player Plugin?
Thanks.
Update
852.7K
Download it from http://www.adobe.com/products/flashplayer/fp_distribution3.html
P.S. just to clarify: the ActiveX and plugin are two separate installers.
Guest
It's pretty confusing.
Do you know what the difference is between Adobe Flash Player
10 ActiveX and Adobe Flash Player Plugin?
I checked out the page associated with the link you provided
and there are several download links. Do you know which link
is for the Adobe Flash Player Plugin?
Thank You For Your Help.
The ActiveX is for Internet Explorer, and the plugin is for all other browsers (Firefox, Opera, Safari, etc.).
Google Chrome does not require Flash Player to be installed, as it is preinstalled in Chrome.
Guest
The system is only about 5 months old. It came with IE8 and Chrome preinstalled.
Chrome 11.0.696.60 and I haven't used it. (Not even once)
Is it possible that the Flash Player Plugin originally listed in - uninstall or change a program -
was intended for that version of the Chrome browser?
I think the plugin may have also been preinstalled. Since I don't have any other browsers
installed I do not know what else it could have been used for.
You are confusing me now; I thought you just want to install the plugin...?
So is it installed?  In Firefox go to http://www.adobe.com/software/flash/about/ - can you see the Flash animation, and the installed version information below?
In C:\Windows\syswow64\Macromed\Flash - what files do you have there?
P.S. if you install the plugin, it will not replace the FP version in Chrome.
Guest
These are the files listed in the folder.
Flash10p.ocx
FlashInstall.log
FlashUtil10p_ActiveX.dll
FlashUtil10p_AciveX.exe
I originally uninstalled Flash Player 10 ActiveX and the Flash Player Plugin
thinking they would both be reinstalled with the newer version. When I installed
the newer version of Flash Player 10 ActiveX I noticed the Plugin was missing
and wondered what happened to it. I didn't know it needed to be downloaded
seperatly and I also didn't know what it was for exactly. As it is right now
everything works and since I'm not using any other browser - downloading
the Plugin isn't required. At least now I have an idea what the Plugin it was
intended for and know it's not needed.
Thank You.
From the files you listed I see that you don't have the plugin installed.
If you want Flash Player to work on Firefox, then you need to install the plugin.
Guest
I'm not using Firefox. I'm using IE8 (against the better judgement of others)
I actually prefer it because I'm so familiar with it. I know what the Plugin is
for now. I saved the executable file  (install_flash_player_10.exe) to a folder.
If I need it I'll install it. You answered my questions and cleared things up.
Thanx.
Guest
I found the file on the page to the link you provided and now know what the Plugin was for.
Thanks again for your help.
Jan 24, 2014 Jan 24, 2014
Hi. I hope you're still around as your answer is from 2008.
I need help re: Adobe, not version 10 of course, because we're in 2014, but 12.
I lost Adobe Flash Player 12 ActiveX and 12 Plugin.
It was after an Adobe update, whose download had the option to get a McAffee Scanning Tool as well to check my security (and something from Windows apparently, called GenuineCheck).
I didn't need the McAffee tool because I got Avast Antivirus and Comodo Firewall, but it was only a quick but thorough check, or so I thought, and so I went for it. It performed the scan and I left it at that.
Oh, it also asked me for unlimited access to my computer! And I gave it. After that, my laptop started working horribly slow, to the point of impotent rage. It took looong minutes to go from page to page, even on the same website, to load links, even save or view pics. I had to uninstall the McAffee Tool and "Genuine"Check.
Now, the process of uninstalation had a warning that, if I went ahead with it, I would also lose Adobe Flash Player 12 ActiveX and the 12 Plugin. Just like that, no alternative.
I had to get rid of McAffee and intended to reinstall AFP 12 ActX and Plugin immediately after. Still, do you see what this means? This McAffee tool came riding on the back of Adobe's reputation and popularity and then, like a good little parasite, when it went, it took Adobe down with it!
Now I only got the pepperspray, which I had disabled ages ago because it does nothing but crash, and the one I downloaded later and now lost, is a goner! My desktop only shows the place where AFP would have been, its name still on the phantom icon, but when I try to open it, it says it is no longer there!
I hope that when you said Flash comes with Chrome you only meant pepperspray and not the one I lost because that's the one I like and work with better (both ActiveX and Chrome). And I'm getting frustrated because everytime I google AFP 12 ActiveX, or even get to the download link, what I see is not the 12 ActiveX but simply Adobe Flash Player. No more.
What on Earth do I have to do or where to go to find AND download AND install AFP 12 ActiveX and 12 Plugin successfully?
And can McAffee be held accountable for causing the loss of software that they used to be downloaded=to profit from, and then totally took the piss of?
HELP PLEASE.
I hope I get a notification of your valuable reply, but I'll bookmark this page anyway, or if you prefer, paulacristinagomes@hotmail.co.uk. Not through the Windows Live Mail you get to if you click on my link, but through Hotmail/Outlook please? I never use Live Mail, it's rubbish.
My best regards and thank you. Paula.
Guest
Jan 26, 2014 Jan 26, 2014
Guest
Jul 10, 2012 Jul 10, 2012
  • chearles
Sep 19, 2016 Sep 19, 2016
ewin 7
Adobe Employee ,
Sep 23, 2016 Sep 23, 2016
Given that this thread was from 2014, and I can't really figure out what you were trying to communicate in your previous post, I'm going to lock this thread.  If you have an actual question, please start a new thread, and include sufficient detail so that we can help.
