CFXML and Namespace References Order
Guest
May 05, 2011 May 05, 2011
I am using cfxml top create an xml file to send to a third party.
There are two Namespace references in the xml.  The problem is that cfxml apparently alphabetizes the reference order.  This results in a "fatal xml error" from the third party I am submitting the xml to.
It's a guess as to the alphabetizing, but CF is definitely switching the references in the resulting xml.
This is what's in my code:
<CFXML variable="MyXML">
<?xml version="1.0"?>
When I view the resulting xml the namespace reference have switched:
Anyone know of a way to get CF to do what I tell it?
Advanced techniques
1.0K
Valorous Hero , May 05, 2011 May 05, 2011
IF you are not using the XML data structure in ColdFusion, and I presume you are just passing an XML string, then just create the XML string directly.
Basically, if you replace the <cfxml....> with <cfsavecontent...> you can get just that.  Just know that with the <cfsavecontent...> version, you are responsible for you own XML prologue.
Valorous Hero ,
Guest
Thank you so much.  That worked just fine.
I'm curious though.  Is it normal for an XML parser to put the namespace references in alpha order?  Or is that just a CF thing?
Thanks again!
Valorous Hero ,
I don't know for sure, I have never had to dig that deep into ColdFusion's XML features.
I can speculate that the XML Object in memory does not have any 'order' to the namespace references (or any other of the references that make up the XML data object).  It is not until that internal object is output as a string representation that the ordering occurs.
It is also a bit of an open question in my mind of why any XML parser should care about the order of elements.  It's sort of a basic premise of XML that order should seldom matter, is it not?
Guest
I absolutely agree that the parser should not care about the order.  It took me two days to figure out that was the reason it was returning a "fatal xml" error.
The only answer I can give is the third party I referenced, hence the operator of that wonderful parser, is a US government agency.  Perhaps not a good answer, but explains much nonetheless (I hope).
Valorous Hero ,
SO is the provider of the assistance you have received today!
Be carefull of those broad brushes in your paint can!
ILSSAC: Worker at a State Government agency.
The government giveth, and the government taketh away.
Dave Watts, CTO, Fig Leaf Software
http://www.figleaf.com/
http://training.figleaf.com/
Guest
Oh, I just KNEW you were going to say that Ilssa!
This a a Federal agency.  A very, very frustrating Federal agency. Perhaps why my paint can has broad brushes.  The color of the paint is "Frustrating Fuchsia".
Sorry about that.  Certainly didn't mean to offend.
Valorous Hero ,
Message was edited by: ilssac to remove the duplicate post.  One just gotta love this Jive forum doesn't one.
Documentation
