I've been having trouble getting JavaScript to run when set to run at "Client and Server". So to try to narrow down the problem, I created a simple new dynamic PDF with a test field on it called "msg". In the docReady event, I placed the following JavaScript code:
this.xfa.form.Ultra_Form.Page1.msg.rawValue = "Test String";
This code works correctly when run at the client, but it does nothing when run at the server (I'm flattening the form through Output).
Any ideas?
- Nathan
Total Likes
The Doc Ready event does not fire on the server ....change the code to the Calculate or Form Ready (I think Form Ready fires on the server _ I do not remember) and it shoudl work.
Paul
Total Likes
Thanks for the suggestion. That didn't work, unfortunately. I tried those two events, plus several others, and while they all worked on the client, none worked on the server. Events I tried include: initialize, calculate, form:ready, layout:ready and docReady. I made sure they were all set to run at "Client and Server", but none of them fired on the server.
Anything else I can check/try?
- Nathan
Total Likes
Look in the server log to see if there are any errors being reported.
Paul
Total Likes
