8 Replies Latest reply: May 7, 2011 6:18 AM by barpos RSS
    allTransitionsOutDone problem
    barpos Community Member
      Can anyone explain why the following code doesn't work completely?
      var industriesTM:TransitionManager = new TransitionManager(IndustriesTxt);
      var usifabTM:TransitionManager = new TransitionManager(UsifabTxt);
      var rawdonTM:TransitionManager = new TransitionManager(RawdonTxt);
      industriesTM.startTransition({type:Blinds, direction:Transition.OUT,  duration:3, easing:None.easeIn, numStrips:25, dimension:0});
      usifabTM.startTransition({type:Blinds, direction:Transition.OUT, duration:3, easing:None.easeIn, numStrips:25, dimension:0});
      rawdonTM.startTransition({type:Blinds, direction:Transition.OUT, duration:3, easing:None.easeIn, numStrips:25, dimension:0});
      industriesTM.addEventListener("allTransitionsOutDone", doneTrans);
      function doneTrans(event:Event):void
      industriesTM.startTransition({type:Blinds, direction:Transition.IN,  duration:3, easing:None.easeIn, numStrips:25, dimension:0});
      usifabTM.startTransition({type:Blinds, direction:Transition.IN, duration:3, easing:None.easeIn, numStrips:25, dimension:0});
      rawdonTM.startTransition({type:Blinds, direction:Transition.IN, duration:3, easing:None.easeIn, numStrips:25, dimension:0});
      The industriesTM.startTransition() line within the listener does not  execute.  If I change the industriesTM.addEventListener to  usifabTM.addEventListener instead, then usifabTM.startTransition() and  industriesTM.startTransition() lines do not execute.
      Why?
      Ron
        • 2. Re: allTransitionsOutDone problem
          Yes, I learned it there, but there's no mention on how to reset things.
          Here's a sample from that link:
          import fl.transitions.*;
          import fl.transitions.easing.*;
          var myTM:TransitionManager = new TransitionManager(my_mc);
          myTM.startTransition({type:Zoom, direction:Transition.IN, duration:7, easing:Strong.easeOut});
          myTM.startTransition({type:Rotate, direction:Transition.IN, duration:7.5, easing:Bounce.easeOut});
          myTM.startTransition({type:PixelDissolve, direction:Transition.IN, duration:5, easing:Strong.easeOut});
          myTM.startTransition({type:Fly, direction:Transition.IN, duration:4, easing:Strong.easeOut});
          By adding multiple .startTransition() lines, you are combining them together as opposed to sequentially executing one by one.
          In my case, one line is Transition.IN and the next Transition.OUT, therefore they conflict.
          Ron
          • 3. Re: allTransitionsOutDone problem
            relaxatraja Community Member
            The code given by you is working fine:
            Note: IndustriesTxt should be a movieclip
            • 4. Re: allTransitionsOutDone problem
              Interesting!  The TXT objects are graphics, but I later used the drop-down to select Movie Clip.  Anyhow, I recreated industriesTXT from scratch as a movieclip right off the bat and the result is the same, no change.  So, I'm at lost here.  I'll try to see if a new test .FLA would behave the same.
              Ron
              • 5. Re: allTransitionsOutDone problem
                I tested it works! can you send the file: relaxatraja@aol.com
                • 6. Re: allTransitionsOutDone problem
                  Sent!  Let me know what you find ...
                  • 7. Re: allTransitionsOutDone problem
                    In your "Main AS3" layer Move your first keyframe with cod to 18th frame it works. The problem is on the tween to confirm that
                    • 8. Re: allTransitionsOutDone problem
                      But, why didn't I think of it???  <g>
                      Anyhow, thanks a lot!
                      Ron
