Pagination in data service not working
Avatar
Level 1
Objective is to show a predefined number of records from the
database and
Populate a datagride.Say there are 50 records in the
database and the
requirement is to show 10 at time. As per documentaion
JavaAdaper needs to be used with page size defined. Tried but it
always return all the rows.
Code:
Mxml file
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml"
xmlns="*" pageTitle="Contact Manager"
creationComplete="initApp()">
<mx:Script>
<![CDATA[
import samples.contact.*;
[Bindable]
public var contacts:ArrayCollection;
[Bindable]
public var contact:Contact;
private var ds:DataService;
private function initApp():void
var i:int;
contacts = new ArrayCollection();
ds = new DataService("contact");
ds.pageSize=4;
ds.autoCommit = false;
ds.fill(contacts);
AsyncToken(ds.fill(contacts));
token.kind = "fill";
</mx:Script>
<mx:DataGrid id="dg" dataProvider="{contacts}"
width="100%" height="100%"
change="contact=Contact(dg.selectedItem)" editable="true" >
<mx:columns>
<mx:DataGridColumn dataField="contactId"
headerText="Id"/>
<mx:DataGridColumn dataField="firstName"
headerText="First Name"/>
<mx:DataGridColumn dataField="lastName" headerText="Last
Name"/>
</mx:columns>
</mx:DataGrid>
Flex-data-service.xml
<destination id="contact">
<adapter ref="java-dao" />
<properties>
<source>samples.contact.ContactAssembler</source>
<scope>request</scope>
<metadata>
<identity property="contactId"/>
</metadata>
<network>
<session-timeout>2</session-timeout>
<paging enabled="true" pageSize="10"/>
<throttle-inbound policy="ERROR" max-frequency="500"/>
<throttle-outbound policy="REPLACE"
</network>
<server>
<fill-method>
<name>loadContacts</name>
</fill-method>
<fill-method>
<params>java.lang.String</params>
</fill-method>
<sync-method>
<name>syncContacts</name>
</sync-method>
</server>
</properties>
</destination>
1 Reply
Avatar
Level 2
This all looks ok to me. If the data grid is displaying all
50 rows, you will see all 50 and might not notice that it was
actually fetching them 10 rows at a time. To see more about what
the server is sending to the client, enable the debug logging in
the server. Go to your services-config.xml (in WEB-INF/flex) and
search for "level=". Change that to Debug and make sure your
<pattern> tags just below that include both "DataService.*"
and "Message.*". When you run the application, you should see
something like:
[Flex] [DEBUG] Before invoke service: data-service
incomingMessage: Flex Message
(flex.data.messages.DataMessage)
operation = fill
id = null
clientId = 5BA19DE7-635A-5F00-819D-AD0AEB206647
correlationId =
destination = contact
messageId = E6389592-D861-9753-1792-AD0AEB20638E
timestamp = 1153954409497
timeToLive = 0
body =
hdr(DSEndpoint) = my-rtmp
hdr(pageSize) = 4
and then:
[Flex] [DEBUG] After invoke service: data-service
reply: Flex Message (flex.data.messages.PagedMessage)
sequenceId = 0
sequenceSize = 13
(no sequence proxies)
clientId = null
correlationId = null
messageId = F27873A5-264C-C0AC-E9E3-C625EE3FEA61
timestamp = 1153954430598
timeToLive = 0
body =
[contactId=3, firstName=Randy, lastName=Carter, address=,
phone=555-555-55
55, zip=],
[contactId=12, firstName=Mary, lastName=Connors, address=,
phone=, zip=],
[contactId=5, firstName=Pierre, lastName=Dupont, address=,
phone=222-222-2
222, zip=],
[contactId=7, firstName=Jose, lastName=Espinosa, address=,
phone=, zip=]
operation = page
id = null
clientId = C406259D-7A45-269E-CB51-AD0B3E282DE1
correlationId =
messageId = F3E58955-27D9-8AF9-5A7C-AD0B3EC48421
timestamp = 1153954430722
timeToLive = 0
body = {}
hdr(sequenceId) = 0
hdr(pageIndex) = 1
hdr(pageSize) = 4
sequenceId = 0
sequenceSize = 13
clientId = null
messageId = F27874D3-E208-C26D-A448-B9AFE682B86D
timeToLive = 0
body =
[contactId=10, firstName=Luis, lastName=Fernandez, address=,
phone=, zip=]
[contactId=15, firstName=Paula, lastName=Green, address=,
phone=, zip=],
[contactId=11, firstName=Chloe, lastName=Jones, address=,
phone=, zip=],
[contactId=9, firstName=Zoe, lastName=King, address=,
phone=, zip=]
Notice that there is first a "fill" message which returns 4
rows, then a page message which returns the next 4 rows. Try making
your initial window smaller and hit "refresh" and then you should
only see those page messages go across when you scroll.
