1. Re: what component to display a matrix
Flex harUI May 6, 2011 11:07 AM (in response to eprevot123)It depends on what else you want to do with it, like selection,
manipulation, animation.
You could just use constraintColumns/constraintRows, or TileLayout, or even
the old MX Grid/GridColumn/GridRow
2. Re: what component to display a matrix
eprevot123 May 9, 2011 1:12 AM (in response to Flex harUI)I would like to be able to scroll vertically and horizontally, and still see the headers (like the datagrid does).
I tried to create a mxml component with DataGroup with TileLayout, surrounded by HGroup and VGroup for the headers but if I set scrollers on the datagroup then the headers don't follow, and if I set scrollers around the hole component then headers disapear when I scroll.
Plus the component takes 7sec to display the 240 cells, I still have to determine which of the model creation or the component displaying takes so long.
Can we have vertical and horizontal headers with MX Grid ?
Since I don't know what will be the number of row/columns, I would have to create the Grid/GridColumn/GridRow in an as file ?
3. Re: what component to display a matrix
eprevot123 May 26, 2011 4:04 AM (in response to Flex harUI)I created a AS component with mx grid/gridRow/gridITem, and other grids for the horizontal and vertical headers, and synchronize the headers's scrollbar with the main grid scrollbars.
It works but it takes a loooong time to display. (about 6 seconds to display 4 columns, 17 rows, a renderer in each cell).
I click on a button to change the state of my application and display the grid.
My AS method to create the Grids/GridRows/GridItems takes 3 seconds to finish, then I receive a "addedToStage" event, and then I wait again 3secs to see the grid.
-> I don't understand the 3 secs between the addedToStage event and the display I see on screen.
-> If I can't reduce the time, at least I would like that the application changes as soon as I change the state, and see each cell displayed as it is created. How to do that ?
Edit : I tested with 20 rows, 20 columns => 1sec to calculate the Grid, 25secs to display the grid !!
4. Re: what component to display a matrix
Flex harUI May 26, 2011 9:44 AM (in response to eprevot123)Comment out the renderers and see how fast it is. It might be something
about the renderers.
5. Re: what component to display a matrix
eprevot123 May 27, 2011 1:20 AM (in response to Flex harUI)Well of course with nothing in the renderer it's almost instantaneous.
But I need these renderers to display the information, otherwise the grid is useless...
Maybe flex draws every renderers instead of drawing only the visible ones.
I tried with DataGroup and TileLayout but has the same problem (too long to display).
You seem to think there is a problem with the renderer, do you have something in mind ? any clue ?
Edit : each renderer contains a Rect (to display the frame to have a grid), 2 labels, 1 textArea, 3 buttons with icon (icon is embeded once in another class)
6. Re: what component to display a matrix
Flex harUI May 27, 2011 10:01 AM (in response to eprevot123)Post the renderer code.
7. Re: what component to display a matrix
eprevot123 May 30, 2011 1:08 AM (in response to Flex harUI)Here is the mxml part of my renderer (Labels are bound on var sound:XMLList that has only one XML element) :
<s:Group>
<s:states>
<s:State id="noSound" name="noSound"/>
<s:State id="soundRecording" name="soundRecording"/>
<s:State id="soundRecorded" name="soundRecorded"/>
</s:states>
<s:Rect width="100%" height="100%" >
<s:fill>
<s:SolidColor id="background" color="0xFFFFFF"/>
</s:fill>
<s:stroke>
<s:SolidColorStroke color="0x000000" weight="1"/>
</s:stroke>
</s:Rect>
<s:Label x="5" y="5"
text="{sound.@id}"
includeInLayout="{isExpanded}" visible="{isExpanded}"/>
<s:Label x="40" y="5"
includeIn="soundRecorded"
text="{sound.@pathName}" toolTip="{sound.@pathName}"
width="100%" maxDisplayedLines="1"/>
<s:TextArea id="descriTA" x="5" y="22"
width="150" height="60"
change="{descriChange(descriTA.text)}" text="{sound.@descri}"/>
<s:Image id="playImage" source="{SoundGrid.playIcon}"
mouseDown="{playImage.source = SoundGrid.playIconDown}"
mouseUp="{playImage.source = SoundGrid.playIcon}" mouseOut="{playImage.source = SoundGrid.playIcon}"
x="5" y="84"
toolTip="play"
click="playClicked()" />
<s:Image id="recordImage" source="{SoundGrid.recordIcon}"
mouseDown="{recordImage.source = SoundGrid.recordIconDown}"
mouseUp="{recordImage.source = SoundGrid.recordIcon}" mouseOut="{recordImage.source = SoundGrid.recordIcon}"
includeIn="noSound"
x="5" y="84"
toolTip="record"
click="recordClicked()"/>
<s:Image id="stopImage" source="{SoundGrid.stopIcon}"
mouseDown="{stopImage.source = SoundGrid.stopIconDown}"
mouseUp="{stopImage.source = SoundGrid.stopIcon}" mouseOut="{stopImage.source = SoundGrid.stopIcon}"
includeIn="soundRecording"
x="5" y="84"
toolTip="stop"
click="stopClicked()"/>
<s:Image id="importImage" source="{SoundGrid.importIcon}"
mouseDown="{importImage.source = SoundGrid.importIconDown}"
mouseUp="{importImage.source = SoundGrid.importIcon}" mouseOut="{importImage.source = SoundGrid.importIcon}"
includeIn="noSound"
x="50" y="84"
toolTip="import"
click="importClicked()"/>
</s:Group> -
8. Re: what component to display a matrix
Flex harUI May 30, 2011 11:19 PM (in response to eprevot123)You might want to use the profiler to see if it shows anything as being
slow. There is lots of bindings which can be slow, and lots of mx:Images
which could be slow if the images are big or external.
9. Re: what component to display a matrix
eprevot123 May 31, 2011 4:00 AM (in response to Flex harUI)In the renderer, it is the textArea and the Images that take the most time. But I still don't know how to speed up the display.
I can remove binding and update the cells myself but I want to have Images in each cell.
Are you saying that this display time is normal ? as long as I use binding and Image (and textArea) I won't be able to display faster the renderers ?
(what is external image ? mine is in the src/assets folder)
10. Re: what component to display a matrix
Flex harUI May 31, 2011 7:56 AM (in response to eprevot123)Images are either embedded or loaded at runtime. Loading at runtime takes
more time. Another factor is the original size of the image vs the
displayed size. If I take a full photograph that is 10's of MB in size and
display it down in a small area, that will also take time.
11. Re: what component to display a matrix
eprevot123 May 31, 2011 8:10 AM (in response to Flex harUI)I embed the images, and they are 4K (16x16 pixels icon).
12. Re: what component to display a matrix
Flex harUI May 31, 2011 10:33 AM (in response to eprevot123)I don't think a 16x16 icon should be 4K in size. If you are asking the
player to scale it down, that may take extra time.
13. Re: what component to display a matrix
eprevot123 Jun 3, 2011 8:40 AM (in response to Flex harUI)I don't set any height/width to the Image, no code to scale the image, it displays it as it is.
Anyway I tried to replace the Images by Buttons without icon, and the time to display the grid is the same. So I don't think I can gain time on this part.
But I tried to replace the TextArea by a Label and it's better.
I added a listener to trace "added" events on the renderer and I see many traces for the scrollers of the TextArea.
I tried to remove the scrollers from the TextArea : scroller="{null}" horizontalScrollPolicy="off" verticalScrollPolicy="off"
But I still trace all the scrollers "added" events.
Is there a way to not calculate scrollers when displaying a spark TextArea ?
And does it seem likely to you that TextArea scrollers are the main source of my problem ?
14. Re: what component to display a matrix
Flex harUI Jun 3, 2011 10:16 AM (in response to eprevot123)Probably. If you don't ever want them, use some component like
RichEditableText that doesn't have scrollbars built in.
